Question about Brother MFC 210C All-In-One InkJet Printer
Unable to print
Using the printer as a photocopier and got a paper jam - removed paper but now message coming up as "Unable to print See Troubleshooting and routine maintenance chapter in User's guide.
Have removed paper - looked right over the whole printer and can't find anything else wrong - desperate for some help
  • 3 more comments
  • MStofila Nov 27, 2007
    Have removed paper - looked right over the whole printer and can't find anything else wrong - after entering maintenance mode, my printer now flashed "machine error 51"
  • 1970al Nov 27, 2007
    Machine error code 50
    Thanks for the help - maintenance code 50 - can you be of any further assistance?
  • Anonymous Mar 23, 2009
    Unfortunately, when I went to the link you provided that supposedly shows how to open up the machine, it's in German. Sorry, only ready/speak English, so this was absolutely no help whatsoever.
  • kells3000
    kells3000 Oct 01, 2012
    hi the message on my printer is saying unable to init.Can you help me thanks
  • 832 Answers
Press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Posted on Nov 26, 2007
  • 3 more comments
  • Mix-it-up
    Mix-it-up Nov 27, 2007
    The paper jam had lifted the encoder strip of the print head. The strip gives the ph the position.
    You have to open the printer and to fix the plastic foil which runs parallel to the ph into the right position.
    Will post you the help later (have to search here because i have it already written and stuffed with pictures)
  • Mix-it-up
    red arrow: encoder strip
  • Mix-it-up
    So here we go:
    open printer (follow pictures):
    http://www.hstt.net/refill-faq/inside.ht...
    turn one of the three gear wheel around (clicking sound) now you can push the ph to the very left side (towards gear wheels). Lift it up here. Reinsert ph encoder strip (red arrow on picture) should go into position. Make a test drive: push ph to the middle and back to very left: watch the encoder strip: it should run straight with no "wave" in front. reassemble printer thats it!
  • Mix-it-up
    @MStofila:
    Error 51 is something different to error 50.
    The purge cam shaft doesnt work well.
    Try to turn the wheel around several times (both way). Watch the purge station (in the pic above beneath the ph). Check encoder strip, too.
  • Mix-it-up
    2nd solution for error 51: watch very well if paper pieces are left on the travelling path way of ph. There might be some paper stuck between the gear wheels, too!
My printer brother MFC-210C "Machine error 51"
Posted on Mar 17, 2009
SOURCE: will not print
You guys did a great job on my printer mfc 210c !! I took it apart like you told me & cleaned the waistinktank & put it back together & yippee it works great !!
Thanx fix ya guys ! Gene77
Posted on Nov 10, 2007
Mix-it-up
  • 832 Answers
SOURCE: Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Posted on Mar 08, 2008
SOURCE: Unable to Clean
Обнулил счетчик
Posted on Jun 23, 2009
SOURCE: unable to print Troubleshooting and
I cannot print my document
Posted on Jul 29, 2009
sardanadixit
  • 813 Answers
SOURCE: unable to print See Troubleshooting and routine maintenance chapt
Download the manuals from:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5440CN_5840CN_EN_108.PDF
and
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_110C_MFC_210C_3240C_3340CN_420CN_5440CN_5840CN_620CN_EN_1266.PDF
Please rate this solution in case you find it helpful, else leave a comment and I shall revert back with more suggestions.
Posted on Aug 11, 2009
Testimonial: "Thank you for the site info! i looked for a long time, wish i had asked and followed your advice the first thing as it went right to it."
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
Carriage Jam problem. Have gone through complete troubleshooting routine, but the message just won't go away. Says ""Carriage Jam". No debris to left or right of carriage. In fact, the jam was in the paper...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Oct 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My printer is asking me to refer to troubleshooting and the routine maintanence chapter in users manuel for - print unable 36 Does anyone know how I go about fixing this? Nikki
Check for a paper jam. I just encountered this same error on my Brother MFC-290C, and that was the cause. I had to unplug the printer's power cable to clear the error message.
Sep 02, 2010 | Brother Office Equipment & Supplies
MFC-240 I had a paper jam the other day and I
May be you should have the printer checked by a qualified technician.
I guess that when you aunt removed the paper, she did it by applying excessive force causing damage to the printer mechanic.
Mar 15, 2010 | Brother Multi-Function Center MFC-240C...
Brother 130c print unable 50
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
Aug 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
I have a color MFC 5 in 1 printer
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it. Sounds like something is jamming.
May 16, 2009 | Brother MFC-5440CN All-In-One InkJet...
Mfc-5460cn
Now the printer bar is all black lines neatly lined up and I can't even shut it off!!!!!!!!!!!!!!!!!!!!!
Oct 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
Not printing
my printer doesnt work, what do i need to do so that i can use my printer again,pls kindly give me the information, it always said that go to the maintenance and routine maintenance chapter. i have no any idea on that device, pls!!! thanks!!!
Jul 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to print
press menu then start mono then 4x arrow-up. machine will be in maintanance mode. what error code does the machine display?
to leave the maintanace mode simply unplug machine from power and reconnect again.
Nov 06, 2007 | Brother DCP-110C All-In-One InkJet Printer
Not printing
Sure. Its a new common problem of brother printers. The paperjam lifted the encoder strip (a foil strip) out of position. The encoder strip gives positioninfo to the printhead. You have to disassemble the printer and simply fix the encoder strip in its position upon the printhead. To avoid this prob in future stick a 3cm tape with a 1cm plastic strip in the middle onto the position where the encoder strip runs thru the printhead. The plastic foil avoids a sticking contact of the encoder strip.
Oct 01, 2007 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
1,705 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
