Zebra Eltron LP 2824 Thermal Printer
Problem for Zebra Eltron LP 2824 Thermal Printer
LPT Zebra UPS Thermal 2844 Printer Printing Slowly
By dwid597 on Aug 05, 2009
When I go to print from this printer it takes 4-30 min to print a small lable. It worked on XP previously. I tried three different drivers. I have Vista Business 32 on a small domain. I tried deleting and reinstalling the printer.
Solution #1
posted on Sep 19, 2009
Somewhat Helpful)
Madison99
Rank: Master
Rating: 83%, 5 votes
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default and dumped whatever settings where mucking it up.
If this doesn't fix you, it is an issue between the software you are using (? what kind is it?) and the printer driver.
Was this helpful?
Yes
No
Solution #2
posted on Sep 24, 2009
Not Rated)
nomail667
Rank: Apprentice
Rating: 0%, 0 votes
Use the LP 2742 driver, with some custum settings it should work 3.1mm on hight under paper and rotate the settings.
Was this helpful?
Yes
No
Popular Solutions for Zebra Eltron LP 2824 Thermal
Questions and Unsolved Problems for Zebra Eltron LP 2824 Thermal
Do you recommend Zebra Eltron LP 2824 Thermal Printer?
Answer
Answer
the printer prints text, but when I change to programming mode, I get the following code: q408... (More)
Answer
Hi we've just changed the label roll on the zebra lp 2824 printer and it now appears to be printing... (More)
Answer
Recently bought 2 eltrons LP2042 printers off ebay to replace the one I had. WhenI put the label... (More)
Answer
I just installed a new ribbon and a continuouslabel roll. Now the printer sticks whenever it tries... (More)
Answer
Zebra LP 2824 print output is OD N D10 S2 ZT q400 No matter what I print.
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
