SOURCE: Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
SOURCE: bosch exxcel multi programme ....programme gets to
this is caused by incorrect water levels the appliance takes in too little water at final rinse and generates erro code 1 this is what you are getting it isnt 1 minute to go it will need the dishwasher equivalent of colonic irrigation several tubes will be full of fatty deposits,using the quick wash a lot will make this happen more often you will need an engineer to sort but shouldnt need any parts.
SOURCE: My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
SOURCE: my Bosch dishwasher SHE4AM12UC will start a cycle
This is due to either a problem with your power board, or your drain pump. Check the drain pump impeller to see if there is any debris causing the impeller not to spin freely. You will need to call a service technician to replace the power board located on the right hand side of the machine base. Also check to see if there is a removable plastic peice in the sump by the drain pump. to do this, removie the sump screen (mesh screen in the floor of your dishwasher) by unscrewing it and pulling it up. This plastic peice (called a lid/cover) fits in the bottom by the drain pump. If this has come loose, then it simply place it back in place and it should fix your problem.
the problem you are describing is either related to the drain pump, or Power board. Perform the simple steps described above, or call a repair technician to come and diagnose it for you. If you are handy, you may be able to replace the board yourself.
SOURCE: connected a new asko 3121
YOUR TIMER IS HOOPED.......ABOUT 228 DOLLARS...BUT EXPECT TOO BE REPLACING YOUR MOTOR SHORTLY...ABOUT $275........IF YOU CA TAKE IT BACK
