Televison & Video Logo
K
Katherine byrne Posted on Feb 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't change channels on my tv I have to watch what my husband is watching on his tv
When he changes his channel my tv changes too
rb3crx
Level 2:
Scholar:
  • Expert 121 Answers
  • Posted on Feb 18, 2019
rb3crx
Expert
Level 2:
Scholar:
Answers
121
Questions
0
Helped
29461
Points
322
Either like what he likes or slip him some sleep aid. This really depends on your cable or internet provider one box cannot be shared on 2 TVs.
mark gardner
Level 2:
  • Expert 234 Answers
mark gardner
Expert
Level 2:
Answers
234
Questions
0
Helped
98107
Points
724
You must have the same brand tv I would suggest getting another brand
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
1helpful
I have a HP PL5060N My TV is going nuts. The channels change on their own no matter if I am watching TV, gaming or watching a movie. I just get booted out of where I am or the TV show to watch the new...
Take the tv aparts.Take the tv manual control board aparts.Reajusting the board and screws it back in.Should solved ur problems,if not than the whole tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal board plug into it,this board have intermittent problems and the causes.Try website like Ebay.com t buy a whole refurbish tv Tuner signal board for the replacement.
While watching, TV made a sharp bang sound. Sound still good, channels can be changed, but no screen, no raster
While watching, TV made a sharp bang sound. Sound Problem with the Zenith Z50PX2D 50 in. HDTV Plasma Television While watching, TV made a sharp bang sound. Sound still good, channels can be changed, but no screen, now tv wont come on at all?
3helpful
2answers
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
1helpful
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
2helpful
My tv channels dont work
Did you follow the suggestion to rescan your channels in the setup?
How to record TV program while watching another
how are the cable hooked up? Is there a TV/VCR button because once you start recording, it is at VCR mode, and you need to hit the TV/VCR button to get you back on TV mode,so that you can watch TV.
2answers
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Can't find a channel to watch a DVD pre-recorded DVD
you should have a input select button on your remote. video 1 should be the front and video 2 should be the back. i had to buy 3 or 4 different universal remotes when mine messed up just to get the one button to change to change it to the inputs because there is no other way to change it to that with he buttons on the tv. kinda surprised that you didn't try and push that button yet.
Record one channel while watchign another
Ouirkygirl, a TV\VCR combo can only watch TV on a channel & record THAT channel. If the monitor is connected directly to the VCR then u should be able to RECORD what u see. Do you have a separate channel changer [buttons that say up\down channel ?] on the face of the VCR portion? If so, then u should be able to change the channel ON the VCR, record that channel, then change the channel ON the TV, .... I don't think so,.........any thing is possable
please explain your words :: "but when I record something it jumps to tha channel evern if I am watching something else at the time."
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
