SOURCE: Tape Loading Error
theres a loading problem with the mechanism. It could be a nylon cam thats cracked and thrown it out of mechanical alighnment??? this is not for the handy man repairer!!! this should be taken to a repair shop for an estimate! as there are hundreds of volts inside a tv that can cause you to be seriously killed!!
SOURCE: vcr eating and/or ejects tape
Tape heads should be cleaned first and gears lubricated. This job can be done at home if you purchase lithium grease and are very careful not to get it on the heads or spools. Greasing should only be done if you are confident in opening it up. Otherwise, seek a cheap professional.
SOURCE: VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
SOURCE: A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
SOURCE: Won't "Play" but FF and
souds like a problem with the main drive motor (most have a couple or a seires of belts).
It's a trip to the repair shop for you I'm affraid
