Question about Dryers
Maytag dryer my dryer flame only comes on once or twice during the cycle and then the flame quits.
  • 213 Answers
There are solinoids on top of the gas valve. the secondary is failing. replaced both solinoids to fix problem
Posted on Nov 27, 2007
Dryer goes on, flame comes on but goes out soon, moisture accumulates on the door, clothes remain wet and very slow drying.
Hello Sam,
What the most likely problem is,is weak gas valve coils,when teh coils are weak the flame comes on when they are cool but once the gas valve coils get warm the quit working. It is a fairly common problem,so common in fact i have written this tip covering weak gas valve coils http://www1.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Oct 19, 2011 | Maytag MGD5600TQ Commercial Dryer
I have a gas Frigidaire dryer that heats once or twice
your cycling/hi-limit switch needs to be replaced,it is located on the outside of the burner tube to avoid an overheat condition and cycle the flame according to your heat setting on the control panel
Mar 14, 2010 | Frigidaire GLGQ332A Gas Dryer
The flame gose on and off it takes 2hr to dry
if the flame only lights once or twice when you first start your dryer, then afterwards the ignitor just glows yet the gas valve does not open producing fire the gas valve coils are defective.
however if the flame goes on and off all during the cycle as it is designed to and your only complaint is the length of time necessary and not that they do not heat i would suggest thoroughly cleaning out your vent line from where it exits the house back to the dryer. correct any crushing of the junk flexible hose by running rigid proper aluminum ducting and elbows to ensure adequate air flow through the exhaust duct.
best of luck,
ttfn
Oct 24, 2009 | Estate Dryers
Maytag DG482 Dryer Won't Heat
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor
a%20igniter.jpg Ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils
part# 279834
The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks. SOURCE
Jul 07, 2009 | Maytag Dryers
Wet clothes after full cycle
Check to see if lint filter is clean.  Also look through the holes inside at the back of the drum to see if there is lint clogging them.  Use a strong shop vac to clean them out if necessary.  The gas flame will normally go on and off during the cycle under the control of the thermostat so that does not sound like the problem unless it fails to come on again when the temperature cools down.  Check to see if air is coming out of the vent outside.  If not, then the blower wheel may be broken.  You will probably have to remove the motor to replace the blower wheel.  I have done it twice on my 34 year old dryer.
May 19, 2009 | Dryers
It takes far too long to dry towels.
The igniter is supposed to go on and off during the cycle. There is a sensor that could be replaced, but is rarely the problem in this instance. 99% of the time when the dryer is taking too long to dry, it is an air restriction. Usually lint is plugged up somewhere, or the vent run is too long.
Mar 13, 2009 | LG DLG5988 Gas Dryer
Maytag dryer only heats for short time
If the dryer has a flame for 2 cycles and then nothing it sounds like your gas coils are failing. Replace them and that should solve your problem
Dec 30, 2008 | Dryers
Maytag Gas Dryer - Flame starts and then turns off 5 seconds into cycle
HI thanks for your question. the coils on the gas valve are faulty . common problem with gas dryers , replace the coils thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Maytag Dryers
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
Top Dryers Experts
