Blinking green light on power switch
Posted by John Gentry on Nov 26, 2007 Report abuse
posted by John Gentry on Nov 26, 2007Report abuse
This phillips Magnavox 26D/32MD251id LCD TX with DVD player is one year old. It will not power up. I tried the manuals suggestion of unplugging it for sixty seconds, same problem.
  • John Gentry Nov 28, 2007
    I have alread registered with you , but I have not received any information that would assist me in solving the problem.
2 Suggested Answers
  • 4 Answers
SOURCE: TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Posted on Feb 28, 2009
Search Results
    2002 saturn l200 headlights and dash lights blinking - Saturn ...
    Mar 6, 2013 - My wife told me that on occasion the headlights and the dash lights willblink when she lets off the. ... 2002 saturn l200 headlights and dash lights blinking.... 2000 LW2 dash lights Inop, spotts56, Saturn L Series Sedans & ...
    Saturn l-300 wagon has flickering lights - Car Forums at > Saturn > Saturn L300
    My wagon 2003 l-300 has flickering lights and when the radio is off you can hear the ...My Dad has a 2002 Saturn Lw series wagon. the transmition has been ...
    why a green light always keep flashing when running? - SaturnFans ... > ... > Models > Saturn S-Series > S-Series General
    Apr 17, 2007 - 20 posts - ‎14 authors
    S-Series General. ... A green light alwyas keep flashing when my saturn 2002 sl2 .... I had a similar issue with the headlights of a 2002 Impala, but it was an .... I never noticed on my SL2, my L200 or on my Ion now if they come ... Flashing Dash Lights
    Oct 20, 2008
    Flickering lights?
    Nov 21, 2007
    L300 2004 - Lights Flickering - Have some help
    Nov 2, 2005
    Flickering Lights
    Feb 5, 2005
    More results from
Feb 09, 2016 | 2002 Saturn L-Series
Power green light Blinking, Will not power up.
Got this from Phillips:
Question My TV has no picture.
Answer Press the menu button on the remote. If the menu appears you are probably experiencing a signal or connection problem.
If you have a menu check the following:
  • Video inputs may be shared. If you have sound but no picture, check that audio and video inputs are going to same.
  • Check antenna connections at the bottom of the TV to see if they are properly connected to the TV.
  • Possible broadcast station trouble. Try another channel.
  • Adjust the contrast and brightness settings. Try another auto picture setting.
  • Check the Closed Captions control. Some TEXT modes could block the screen.
  • Check if you selected the correct AV source. (For LCD TV with built-in DVD player, the correct DVD source is AV1.)
If you have been watching the set and you loose picture:
Your TV has a protective mode in case there is too much heat build-up. Check the clearance around the vents of the device to be certain there are no blocking walls or cabinets which would limit the air flow.
Is it installed in a TV cabinet? These models produce a lot more heat than you think. So the last suggestion is a likely culprit.
One other possibility. Some models have these, some don't but look for a small "red reset button" recessed some where in the back of the set near the power cord. It is a built in circuit breaker.
Nov 26, 2007 | Televison & Video
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from
Why won't my dishwasher start and why does the "Heated Dry" > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from
Washer Sensing led (Green) on with the lid locking led (Red ... > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Phillips LCD TV,green power light changes to red blinking light when power button is pic and no sound.
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Please post back what you find
Dec 18, 2009 | Televison & Video
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Have you heard anything about this?
Hi, try the monitor on another PC , if you got a laptop you try it , to see if it is the monitor . The problem could the video card on your PC., let me know if the light is yellow or green.
Nov 21, 2007 | Dell E173FP 17" LCD Monitor
Coby TF-DVD7006.
The second question, I couldnt work that one out at first, but now i think I understand. If you plug the player into the mains, turn it on, red light shows. Light turns green when battery charged. Do not use until light turns green (if plugged into mains). In other words dont use the player while the battery is charging. If it isnt plugged into the mains then the battery cant be charging and you can use. Until battery gets too low :)
Nov 13, 2007 | Coby TF-DVD7006
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
