Ricoh Aficio 1027 All-In-One Laser Printer
Problem for Ricoh Aficio 1027 All-In-One Laser Printer
Aficio sp4100n sc541 error
By Jmm4444 on Aug 05, 2009
I have the exact same error. I was told this was an error to do with the thermistor of fusing unit I have replaced the fuser and still have the same error.
Solution #1
posted on Sep 16, 2009
Not Rated)
derekrvincen
Rank: Guru
Rating: 87%, 29 votes
the fuser code needs to be reset, this can only be done by a technician, I would bite the bullet and have someone come and reset the code also if you kept the old fuser unit you may be able to get them to replace the thermistors also for not much more.
if this answers your query please rate accordingly.
Thanks
Was this helpful?
Yes
No
Solution #2
posted on Aug 29, 2009
Not Rated)
delfortomac
Rank: Guru  Ricoh Expert
Rating: 95%, 17 votes
Press total clear press 1 0 7 and press for more off 3 second the clear stop key to enter to service program mode.
Then enter SP 5-810 (SC code reset),
select execute, select close. Exit
SP mode, turn the main power
switch off then on.
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 1027 All-In-One
Questions and Unsolved Problems for Ricoh Aficio 1027 All-In-One
Do you recommend Ricoh Aficio 1027 All-In-One Laser Printer?
Answer
Answer
I have an Epsom Stylus DX5050 which is refusing to print - photocopies ok; no red lights; plugged in... (More)
Answer
Is there a way for me to see the list of jams on my Ricoh Aficio 1022?
Answer
aficio says paper stuck in auto doc feeder but nothing there. On off has not worked. Help!
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
