Just recently when I try to charge my LG Venus in the car with the car charger it does not charge. However, it charges just fine with my home charger. It is not the car charger because my wifes phone works just fine with it. Im wondering how can my phone not charge in the car, but charge just fine using the home charger.............help!!!...........thanks!..
Hi friend, if you have any problem with Phone repair Solution and repair tools,or car issue, please read on www.vipprogrammer.com. all of phone repair tools, and you can find it. or add whatsapp: +8615767956655, all the help is free, and we have high quality phone repair tools with Lifetime Warranty and we are China Brand Universal Programmer Online Shop, reply me to know more:)
SOURCE: Will not charge using car charger
if you have insurence you can go to the phone company and ask them to replace it
SOURCE: phone says unable to charge
Try a different battery. If that doesnt work, it may be your charger port. Take an old tooth brush, turn off the phone spray alcahol on the toothbrush, and scrub the port on the phone. If that fails your charger port needs to be replaced. Check with your provider about the warranty. If its not under warranty, check my profile and we can help you for sure.
SOURCE: LG shine wont charge
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
SOURCE: Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
