Question about Dishwashers
Bosch dishwasher Over the weekend my drains backed up into the dishwasher. After cleaning the drains I ran the dishwasher 3 times. Under the screen there is still about an inch of water. I never noticed this before because I never removed the screen before. Can you tell me if this is normal or is there a problem with the dishwasher. The water in the little area below the screen is clean.
  • 213 Answers
Its normal. its there to keep moisture around the rubber seals so they dont dry out.
Posted on Nov 27, 2007
Hi, if its still under warranty you should call bosch and get them to arrange a service engineer to come out and check it for a fault.
Jan 15, 2016 | Bosch Dishwashers
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
Water not draining suspect a piece of smashed glass preventing drainage. I have removed and cleaned all filters.
I had the very dame problem with a Kenmore dishwasher this past weekend. Had to remove all the part on the inside to get to the drain line hook up point. Used a small wire snake to clean out drain line. Also be a good idea to check and make sure your actual drain line is not the problem.
May 10, 2011 | Bosch Dishwashers
I have a Bosch Dishwasher. It will not drain. Our
ck the drain hose ( from the disposal to dw pump . ) you can not run dw with water due to the pressure sw . ck the drain pump also you can use a jumper test cord its 110 volts. .. may be the pump is bad .
Dec 07, 2009 | Refrigerators
My Bosch shx46A05UC no longer will
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
This is a very good web site. Thx for pulling it
It is possible the check valve is sticking causing sour water to come back into the washer. The check valve is located where the drain line connects to the back of the dishwasher. Also make sure the drain line is higher than where the line connects to the drain under the sink. Most washing machines have a loop built into the line but it helps it to drain better when the line is higher. Try hooking the line to the top of the cabinet under the sink if possible.
Sep 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHE45M - Drain problem
please check whether you have something in the drainpump locking it up or a blockage somewhere between the sink and the unit or the pump itself has failed or not.
May 04, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Leaks, doesnt drain properly and cloudy film on glasses
u have water under dw .and overfill switch turninng on only  drain pump all time.second from bosch water  water never leaks on floor.
Sep 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Sensotronic dishwasher will not drain
I think I may have figured out a work around (by accident).  Start a cycle (any cycle), once it starts hold down Scrub Wash and Delicate/Economy at the same time for 3 seconds and the cycle will immediately finish (counting down quickly then to CL) and it will begin to drain.  I had to do this 3 times(draining more each time) but the end result was a completely empty bottom of the Dishwasher. To be honest I think this is the first time the thing has ever been completely empty!  I wish I was joking...
Nov 05, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
124 people viewed this question
Top Dishwashers Experts
