Question about Sony Audio Players & Recorders
I have a Sony blue ray surround sound home theater system and the player says no disc do this mean the firmware need update cause I done tried everything else cleaning it etc
SOURCE:
  • 45 Answers
SOURCE: firmware update
Here's the link to the newest firmware.
http://tinyurl.com/54a9wo
Posted on Jun 15, 2008
SOURCE: needing a remote control for a ht3915 home theater surround sound
code for dish remote to control DYNEX LTDVD20
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
SOURCE: firmware update for Element Blu-ray player
Sorry to bring up an old thread but I couldn't solve the problem with these solutions. I tried a DVD, I tried 3 CD's burned from 2 different computers, I waited for 5 minutes, I waited for 5 hours. Nothing worked. So I used my work computer that is running XP and it worked perfectly. So if you are burning the disk from a vista computer I don't think it will work.
Posted on Apr 22, 2010
RCA RT2760 home theater. I have Insignia blu ray player connected. The surround sound works for the ads on the disc, but when the actual movie starts, there's no sound.
Generally the adds are in conventional sound, not Dolby Digital or any superior sound. So when the movie starts the sound switches to the better sound, which you appear to have not connected it up or have not get the right sound settings selected. So you hear nothing. The Blue Ray player might have to have a either an RCA cable connection, or more likely an optical lead to hear the Dolby Sound types.
Oct 02, 2016 | RCA RT2760 System
Purchased the LHB335 Network blue ray disc home theater system. Hooked it up with an HDMI cable. We can only get the surround sound to work thru the DVD player. We either don't know what in put to have the...
If you can take very close up pics of the back of the blu ray, and the connection site on the tv and foward to my email I can tell you exactly how everything should be hooked uo, marpltvt86@aol.com. Usually its just a simle issue of relocating a wire or 2
Mar 06, 2011 | LG LHB335 Theater System
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Feb 26, 2011 | Panasonic SC-BT200 Home Theater Systems....
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
Jan 27, 2011 | Samsung HTC5500 Theater System
Blue ray dvd does not play blue ray movies. It will play regular dvd
In most cases, the issue might be with the Java contents on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
You can enter the model # of your Blu-ray Player to download the firmware update for your player.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
Jan 15, 2011 | Sony Televison & Video
I have a Sony BDP300 Blue Ray DVD Player. It plays non-blue ray dvd's fine. It plays a Celine Dion Blue Ray DVD fine. Tried to play an Netflex Blue Ray Amiela Earhart DVD and get picture but no sound. ...
I suggest that you install the latest firmware update to resolve the issue. Please click the following link to download the latest firmware update.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder. Most of the customers will be making mistake here after... We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image. I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Aug 14, 2010 | Sony BDP-S300 Blu-Ray Disc Player
We have a samsung blue ray player BD-P1400. We've had it a year and it acted up from day 1. Now it won't play blue ray discs - it says "cannot play disc".
http://www.samsung.com/us/support/download/supportDown.do?group=mp3audiovideo&type=blu_ray&subtype=blu_raydiscplayers&model_nm=BD-P1400&language=&dType=D&mType=FM&vType=R&prd_ia_cd= This is the link to Samsung for firmware updates. All manufacturers have had several updates moving on with disc technology. If you can't burn this to a disc as data, then email samsung and they will send you an update disc. Next, if you don't have one, get a Laser Lense Cleaner. Preferably one that uses liquid, and run that thru a couple times. Clean your players often! it's a good habit to get in to. Hope this helps
Jun 11, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
29 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
