Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi VS-50605 - Colors separated
I have a Mitsubishi VS-50605 projection tv made in July 1999. The colors just recently separated. As an example, when you adjust the volume, the volume levels shows up twice. One in red, and one in green just underneath the red one.
Does anyone know what could be wrong with this tv?
  • 1 more comment
  • gunnarb Nov 26, 2007
    How do I reset?
  • lawrence123 Dec 09, 2007
    1993 50 inch big screen only the red color is not alligned how can i fix this at home
  • Anonymous Dec 10, 2007
    My Mtsubishi VS-50605 is very dim in color when first turned on after sitting for awhile. It is almost in black an white but very dim as well. After it warms up the color comes in great but the screen jumps around all the time. It seems to occur in the upper 1/4 of the screen. We did have a satellite provider out and she informed us that we need to replace the bulbs. When I called Mitz. support they could not understand my request. Please help!!!
    Genius:
  • 1,153 Answers
You have a convergence problem and need to reset
Posted on Nov 26, 2007
The colors aren't matching up I have green semi
Yoy have convergence issue with tv,try the magic focus/touch focus or manual adjustment in the menu under convergence, if can't be adjusted then your convergence ckt is the problem,you will need a tv tech to repair it.
Mar 19, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Changed IC converters, 1-2 message (no problems?)
Are you talking about your convergence ICs ? and Did you use STK392-570s?
Dec 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
The color on my mitsubishi model # vs-5041 is faded and foggy.
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Hope this helps :)
Sep 16, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Blue Screen
no those tvs came with a black otuer screen that have rough ridges . If your screen is blue, someone may have replaced it with a dark colored plastic. You can get replacement screens at the following link, They are exspensive though.
http://servicemanuals.vstore.ca/
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Tv problem
replace both convergence ICs STK392-110 they are available at the following link and they give free installation instructions and free online tech support. The repair is easy and takes about 45 minutes from start to finish.
Mar 05, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Suddenly convergence problem
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 31, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi 50" VS 50605
we need to know if the lines are of different colors or are they white and the screen is too bright ?, 275.00 seems a lot just to get it check out but it all depends were you are,in NY that could be a going charge but in pittsburgh it seems too much,please let us know what the lines look like.
Oct 09, 2006 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
189 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
