My FE-310 camera fell on concrete and the LCD screen got damaged. Still can see the screen but on approx 30% of the area only. The camera still works as I took 50 more pictures and downloaded them. How much would cost to replace it?
Hi, To get that repaired will cost you about $58.85. This does not include the shipping to send it back to Olympus. They will call you if for some reason the camera couldn't be repaired and more then likely offer you a deal on a new one or some kind of replacement. This doesn't sound like it is that much of a problem to replace so you should be able to get that done with no problem. I am sending you the link for the forms you will need. There is one that gives you instructions on shipping your camera and the other one is a repair form you will need to print out and send with your camera. Here is that link:
the lens stays out. sometimes when you press the on button the lens goes in then comes out again. ...
(More)
the lens stays out. sometimes when you press the on button the lens goes in then comes out again. the screen is not going on but is not cracked or damaged.
Whenever i turn on my camera its says "Clean Contact area of the card with a dry cloth" I...
(More)
Whenever i turn on my camera its says "Clean Contact area of the card with a dry cloth" I ve done that everything you could think of. It gives you to options Clean Card or Format. I have done both and neither had worked
