Question about IBM Office Equipment & Supplies
I NEED "IBM SELECTRIC TYPEWRITER MOTOR BRUSHES"... CAN YOU HELP?
My IBM SELECTRIC TYPEWRITER is in great shape, but the MOTOR BRUSHES are not! Anyone have a source for them? Thank you! Anthony
    New Friend:
  • 21 Answers
Is there any electric motor repair shops near you? if not try this one:
http://www.reselectricmotors.com/
if not that one the people at koontz-wagner are usually able to help me.
https://www.koontz-wagner.com/
Posted on Feb 14, 2019
Testimonial: "GREAT! I will try them both today! Your thoughts and time are much appreciated, Anthony"
SOURCE:
JayBlair
  • 328 Answers
SOURCE: return key is stuck
Need more info. Many different possibilities.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 12, 2008
Geno111
  • 183 Answers
SOURCE: Ribbon not advancing on Selectric II typewriter
on the left far side of the ribbon there is a white vertical post. the ribbon should be on the left side of that. also make sure you turn the ribbon the direction of the arrow (on the cassete) otherwise will need professional repair
Posted on Nov 19, 2008
SOURCE: IBM Selectric does not turn on when plugged in.
check the link between the keyboard and the actual switch that turns the machine on.
Posted on Mar 27, 2009
  • 3594 Answers
SOURCE: How to change the ribbon on an IBM selectric II
If this is acorrecting T/W there is ared lever to the rt. of the ribbon rotate it to the front of the ribbon, pull the old ribbon up and off, drop the new ribbon on the ribbon deck, thread the ribbon to the left of the shock wire right where it comes out of the cassette, thread through the lift guides on either side of the element, turn the knob ccw to take up the slack, check to be sure the ribbon is not folded or twisted, move the red lever back.
DickyO
Posted on Apr 30, 2009
  • 46 Answers
SOURCE: Changing typewriter ribbon in the IBM Selectric
You haven't told what model of Selectric. If it is a selectric II or III, there is an orange lever on the carrier that you must pull to one side. The correction tape has a silver lever next to the take-up spool that you must pull outward.
Posted on Jun 26, 2009
Anyone got a possible answer for why my IBM correcting Selectric II won't come on?
If you know how to remove the upper cover there are a few things you can check. turn it on if the motor is trying to turn it may be gummy motor bearings lube them If it dosen't try the off on switch may be gummy. almost anything you will need a tech.
DickyO
Oct 08, 2014 | IBM Correcting Selectric II
Recommendation for IBM Repair Company
I Googled Typewriter repair Washington DC and got 4. I have no idea what they charge.
DickyO
Apr 02, 2014 | IBM Correcting Selectric II
Problem with Selectric II typewriter engaging when turned on
Your on/off switch may be bad but it sounds like your motor needs to be flushed, lubed, and possibly have a bushing installed.
May 16, 2013 | IBM Correcting Selectric II
Not correcting & corrector ribbon not moving to correct
At this point almost all selectrics suffer from a case of the gummies.
it most likely needs a tech that under stands the selectric.
DickyO
Aug 28, 2012 | IBM Correcting Selectric Iii Typewriter...
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
Try a new cord if that dosen't help tou probably need a tech.
DickyO
Mar 26, 2009 | IBM Wheelwriter 30 Typewriter
Mar 11, 2009 | Office Equipment & Supplies
24 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
