Question about Fuji FinePix S5000 Digital Camera
Flash The pop up flash has stopped working , it does not flash , new batteries don't help.
  • 121 Answers
Sounds like the bulb might be a gonner. Can you hear it charge when you turn it on flash mode?
Posted on Nov 26, 2007
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Nikon d90 built in flash not working. Can anybody help with this problem please.when I have the camera in the correct modes the flash pops up but doesn't flash,but the pre illuminator does work.there
your flash is stuck.. you can just manually pull it up and it should work.. I have seen this a hundred times.... don't mangle it but a little squeeze and pull from the front should pop it.
Nov 03, 2012 | Cameras
Flash won't pop up
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
METZ 45 CT 5 S O S
Check the polarity of the batteries.
With the batteries removed you will be able to see small
+ and - alongside each of the six connectors. Make sure the +
of the battery connects with the + connector. Similarly check the -
connections. With the batteries inserted (but without the plastic cap being fitted) you should see the ends of the batteries. Three positive ends (all in a row) and three negative ends.
If one, or more, has been inserted with the polarity reversed it will stop the flash from working.
It can also cause the handle to overheat.
May 02, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Error "Err05" keeps initiating preventing flash operating
There are two versions of this problem: 1. The flash does not pop-up. 2. The flash does pop-up.
Here’s the fix to the err05 msg when the flash does pop-up. This will work on the XTi and perhaps on similar Canon cameras:
The pop-up flash has two legs. Look at the pivot point of the right leg (”right” when looking into the lens). Just in front of the pivot is a very small spring-load pin on the “roof” of the camera body.
This pin is the sensor that tells the camera the state of the flash. The pin is pushed down when the pop-up flash is closed and is suppose to quickly spring up when the flash is opened. Problem is, the pin sometimes gets dirty and drags. When it is slow to spring up … you get the err05 message.
Fix: Take a small jeweler’s screwdriver and dip the tip in isopropyl alcohol. (Don’t use any other solvent unless it’s designed for cleaning electronic parts!) Then touch the screwdriver tip to the pin. Do this several times until the pin area is nicely wet. Then push the pin up and down until it is able to spring up quickly.
Jan 20, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Sony Cyber-Shot DSC-F707 ...No flash.
Same problem for me. The flash won't pop-up anymore, even when I select the forced flash.
Jan 12, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Flash is not working
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
Oct 05, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
My flash don´t recicle more
Never use Heavy duty batteries they do not have high output. They are for clocks. and they're cheap. Clean the contacts with a pencil eraser too.
Sep 12, 2007 | Canon Speedlite 550EX TTL Flash
Fuji FinePix S5000 Digital Camera Logo
113 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
