My iPAQ h1945 Pocket PC screen is not responding to touch...the stylus does nothing. I attempted a hard reset, but I can't align the screen because the stylus still does not work. No apparent cause for this problem...any suggestions?
Comments:
Nov 26, 2007
- I gave the wrong model number--it's actually an hx2415.
-   my touch screen for poket pc e400 is not working even with a stylus. the company is toshiba!
WHAT SHOULD I DO???
-   Guest
Aug 23, 2008
-   I have an iPAQ pocket pc and when the stylus is used it is out of alignment. I can't find the reset button on the pda. Everything lights up. When I go to the setting screen and attempt to touch the align line the screen goes to another page. HELP!-   Guest
i had the same problem and figured out that when i put the screen protector on that it got between the housing and the screen and put just enough preasure on the screen it would not let you do anything.if you put your finger on the screen and apply some preasure and then try to use the stylus it will not allow you to .hope this helps someone.
Was this helpful?
Yes
No
Solution #2
posted on Sep 25, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
im not sure what kind mine is but its having the same problem, I havent used it for around a year or 2... Could it just be broken or is the thing fixable?
Solved same problem.
Same model ipaq 1940.
Sorry for my bad english;this is what You can do:
Open the ipaq
Remove the mainboard
My problem was the connection between LCD and Touchscreen.
So I solved putting on the connection 3cm of tape to have a fully
working contact.Indeed, the lower part of cable, with the 2 little
holes was disconnected.
After this all becames to life!
I hope helps!
Vit :-)
In italiano: 3 cm di nastro adesivo fra LCD e touchscreen.Il loro
contatto non era perfetto.Ora tutto funziona.Con un po' di manualità si
riesce a fare senza problemi!
Saluti, Vit
I have no sound on my Ipaq3830, and my battery discharges to quickly. I have replaced the battery,...
(More)
I have no sound on my Ipaq3830, and my battery discharges to quickly. I have replaced the battery, but I think that the fact I have no sound, points to a hardware issue
over heated my battery on my I-paq and now it will not charge. will i lose my data (excell) if I...
(More)
over heated my battery on my I-paq and now it will not charge. will i lose my data (excell) if I change my battery and will that fix my charging problem
how do i transfer data from a usb flash drive onto my ipaq PDA. the ipaq PDA does not have a usb...
(More)
how do i transfer data from a usb flash drive onto my ipaq PDA. the ipaq PDA does not have a usb port
My pocket cd is so ruined it cant run in my drive, so i cant install my drivers for the pda on the...
(More)
My pocket cd is so ruined it cant run in my drive, so i cant install my drivers for the pda on the comp, and i need to install my TOMTOM Navigator, but i cant get it insatlled on my PDA, the files is transfered but the program isent there..? What should i do?
