Drain. while the motor is still running. I see that one problem is a broken drive motor coupler. I have removed the three bolts at the bottom of the tub, but am unable to separate the parts from the tub, in order to replace parts. Can someone help? Thanks
STOP STOP if you lay it on the back watch the drain hose you will see the pump 2 clips..undo by sliding clips over edge take hoses off pump and remove pump.unplug motor connector plug wires 2more clips hold the motor but they have screws in them you need to take out push them off then pull motor out change coupler PUT THREE BOLTS IN TUB BACK...
