AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2 2x512kb Fsb1000 Pib
Problem for AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2 2x512kb Fsb1000 Pib...
AMD Athlon 64x2 brisbane 2.9 ghz fans too loud now WHAT TO DO!!!
By spence_hiya on Aug 05, 2009
i have upgraded my AMD sempron 2.2ghz which was not too bad on performance to a AMD Athlon 64x2 brisbane 2.9 ghz (AM2 socket) and it has got really loud my fan is so noisy and i am thinking of buying a amd copper core cooling heatsink for it is this the right thing too do please help my computer sounds like it is going to blow up some times
SPECS
Motherboard: Acer F690GVM
Proccesor:AMD Athlon 64x2 brisbane 2.9 ghz
DDR2 RAM: 2.5 gig
Hard Drive: 160 seagate partitioned to 2 80 gig's
PSU: 500 watt
Heatsink and fan: a shity acer that runs dead loud my ears bleed
Graphics:NVIDIA GeForce 8600 GT
more info on proccesor:
2.90 gigahertz AMD Athlon 64 X2 Dual Core
128 kilobyte primary memory cache
512 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded
Comments:
Aug 05, 2009
- hi thank s sorry but the fan has to be a three pin connector or can some one please tell me where to plug a 4 pin in on my board thanks all :)
Best Solution
posted on Aug 05, 2009
Helpful)
Hank94170
Rank: Guru
Rating: 88%, 96 votes
I'd go with the Arctic Cooling Freezer 64. I have one on my SLI comp with two vid cards and the Freezer. With smart fan software they are all really quiet. Just make sure you have room for it in your 'puter, and you select the right one (they have one for intel)
It's HUGE....
They also make a low profile but not familiar with it.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010110574%2050002107&name=ARCTIC%20COOLING
Hank
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Helpful)
Cool_dud 09
Rank: Guru
Rating: 85%, 129 votes
Hai, So you are so sticked towards AMD... If u r expecting for Games then good,for good reliable performance in Applications+Games i recommend Intel rather than AMD.Usually the heat production by AMD causes a lot problem but less in Intel.  Nvidia Geforce 8400GT its good. U can also go for 8800GT some what having similar chip that uses in 9 series.
Was this helpful?
Yes
No
Solution #3
posted on Aug 23, 2009
Very Helpful)
cubanyero
Rank: Apprentice
Rating: 100%, 2 votes
If you have no heating problems,and you used good cooling paste ,for resplace the CPU ,only loud problems, you can leave the original copper core cooling fan.first reset the pc, when you see the Welcome window of the motherboard (ASUS FOXCOMM, BIOSTAR ECT) click delete repeatedly, you will enter the bios setup, very carefully,only looking for (cool and quiet) and check this, you can also need to check the CPU temperature ,,normal is 35 C to 45 C ,(if the temperature is over 50 C,reistall the CPU and used new cooler paste) ,then you give scape. save the changes and restart the PC, now the motherboard fan speed controlled, as required, only spun faster when you really need to cool the prossesador, such as a very graphical game ect, really going to notice a big change cpu fan sound, if that cool and quiet and had been activated o this is a factory PC like DELL ,ACER ,ect ,and have no change, you can buy a new cpu fan on e-bay very cheap,like factory amd 64x2 6000 cpu fan and for no will have more trouble
Comments:
Aug 24, 2009
- Almost every motherboard have 2 or 3 connectors for fans, those are the 4 pin cpu fan, the 3-pin case fan, wanted to that is the reason for your problem, you should look good around the CPU socket, to better assist you, I need the make and model of your PC, and if it is custom, motherboard model, are usually large letters and numbers in white letters, I wait for your answer
Was this helpful?
Yes
No
Popular Solutions for AMD Athlon 64 X2 5600+ 2.9 Ghz
Questions and Unsolved Problems for AMD Athlon 64 X2 5600+ 2.9 Ghz
Do you recommend AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2 2x512kb Fsb1000 Pib ?
Answer
Answer
compatible processor for a E187242 mother board Dimension 5050c
Answer
want let me go in internet even so i have connection whit wirreles every time thtat i try it beasy... (More)
Answer
cant go in internet
Answer
i need a grapics sis vga 370 that compatible for windows xp
Answer
i want to register with intel support for my processor so how i do this please help me
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For AMD Athlon 64 X2 5600+ 2.9 Ghz...:
Top Processor Experts
Rank: Guru Guru
Solutions: 14810
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Processor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
