Question about The Office Equipment & Supplies
You may be able to reach into the housing and pull them over to the center position. Be sure you have the access lid or door completely open before to attempt any cartridge change. You may also try to unplug the unit for about 15 seconds and try to reopen the lid. I hope this helps.
Posted on Feb 12, 2019
SOURCE: I have a Epson Stylus nx200 brand new, and am
turn it on, flip open the panel to get to the ink, press and hold the ink botton under the paper feeding botton, it'll start to move, then when it slides over press the ink botton, it'll shift, continue to press it till it slides to the open area for your ink to be installed
Posted on Jan 29, 2010
SOURCE: Printer Wont print even with new ink
that means, 1 or more of the carts is showing low on ink or it might not being recognized. it might be the ink has a problem or the printer has a problem that it cant recognize the ink. try to Remove and reInstall Cartridges,
Press the Stop button. The print head moves to the
position to indicate which cartridge is low or expended.
Press the
Stop button again.
If another cartridge is low or expended, the print head moves to the
position. Press the
Stop button again to see if more cartridges are expended.
If no other cartridges are low or expended, the print head moves to the replacement position on the right.
once you've identify w/c color has a problem, and removing and reinserting it does not resolve the issue, try another ink of that same color, if the issue persist, that means the printer is broken, call epson to get a replacement printer if it is with in 1 yr. from the date of purchase
Posted on Feb 18, 2010
SOURCE: whenever I slide the phone closed and then slide i...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Posted on May 23, 2010
SOURCE: I have an Epson Stylus
You will need to press the STOP button for the cartridge carrier to move to
the ink change position.
Additional information can be found at Epson support page.
Click on link below and mouse to Remove and Install Catridges at bottom of web page.
http://files.support.epson.com/htmldocs/nx200_/nx200_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=NX200UG.1.100.html
Posted on Mar 11, 2011
Dec 05, 2014 | Epson Stylus NX200 Printer
Aug 18, 2014 | Epson NX200/SX200/TX200
May 15, 2012 | Epson NX200/SX200/TX200
Nov 15, 2011 | Epson Stylus NX200 Printer
May 17, 2017 | Epson Stylus C60 InkJet Printer
May 26, 2011 | Epson Stylus NX200 Printer
Mar 10, 2011 | Epson Stylus NX200 Printer
Mar 11, 2010 | Epson Stylus NX200 Printer
Oct 18, 2009 | Epson Stylus NX200 Printer
Aug 18, 2008 | Brother MFC 240C All-In-One InkJet Printer
23 people viewed this question
