Question about Sharp Televison & Video
Sharp LC-32HG5341K yelow K on the left screen . How can i fix it ?please help me ?
    Habit-Forming:
    Scholar:
  • 47 Answers
This sounds like a programming error. Using the remote try to push and hold down the exit button. If this does not correct the problem, unplug the unit for 15-20 seconds. Plug unit back up and hit the start button. The unit will most likely reprogram you desired settings. I hope this helps with your problem.
Posted on Feb 12, 2019
  • Alexandru Ionut
    Alexandru Ionut Feb 12, 2019
    Thanks for your answer but that didnt helped me .
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
X41900 116520
bestdarngood
  • 3037 Answers
SOURCE: sharp lc26sh20u 26"flat panel has vertical lines on left side,What coulb be problem?
This line would either indicate a horizontal problem cropping up or a power supply problem
I would suggest getting a service tech to look at it to determine where your problem is coming from but most likely it will be the power supply /deflection board that is the problem but I can't know for sure, it will have to be checked.
A lot of sets have had damages after a long hot summer a/c flipping off and on and current demand being peeked from the utilities storms or quick power loss off and on can cause problems like this to occur
Please let me know if you have any other questions, thanks
Posted on May 14, 2008
  • 58 Answers
SOURCE: sharp lc-46d64u broken screens
if the screen is broke its not worth the repair
Posted on Dec 08, 2008
  • 479 Answers
SOURCE: Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Posted on Dec 14, 2008
bshldn
  • 736 Answers
SOURCE: I have a Sharp AQUOS LC-32D47UA 32", black box
Press the cc button on your remote control. You want cc to be off. Play around with the cc button to become comfortable. Press it over and over again. Observed that a different closed captioning option appears on your screen each time you press the cc button. Now press cc and when it says cc off do not press the button anymore.
Posted on Jan 23, 2011
  • 58190 Answers
SOURCE: Picture won't fit the screen on my sharp Aquos LC-60LE640U. How do I fix this?
in main menu change the aspect ratio to a lower number
Posted on Apr 30, 2015
Sharp TV won't turn back on! Help please?
It sounds that the main power regulator board to your TV has damaged. Contact any service technician.
Jul 12, 2013 | Sharp LC-42D69U AQUOS 42 In. 1080p LCD...
Sharp LC-26D6U turns on to a blue screen
Your set need a though check up. It sounds that the main digital board has damaged. Before make it sure, contact any service technician and make it confirm. A panel fault too can cause this. If you wish to get more details about this kind of fault, check this link. http://electronicshelponline.blogspot.com/ If you're sound in electronics, you can follow the rest. Pull up older posts there, either by its left side bar, or, see it in 'Timeslide' option.
Jun 22, 2013 | Sharp LC-26D6U 26 in. LCD Television
Sharp tv lc 32sh12u menu
Just open the menu by using the universal remote control, and do the rest by using Up/Dn & Left/Right buttons at the the TV front panel.
Jan 29, 2013 | Sharp LC-32SH12U TV
My Sharp LC-45GX6U gives only a white screen when I turn it on.
Can you guys please elaborate on what the work-around was for this issue?
Feb 19, 2011 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Apr 22, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp lc-46d64u broken screens
Dec 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Line in middle of LCD screen
I too had a black line horizontally across the screen (on a 52" d62). It was brand new and was as if the screen had been "pinched" at the end of the line and it radiated outward (in my case, the "pinch" was at the extreme left and line went out to the right, like a crack).
Mine was a factory defect (right out of the box) and was replaced (2 yr now and no issues). This line of yours may have been there from the start and maybe you just didn't notice it?? Not a slam, just an observation.
Feb 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Lcd screen
I need Board for model Sharp Aquos LC-15S1E 15 in., so if you still have it contact me. My e-mail: ismedin_grahic@hotmail.com
Sep 05, 2007 | Sharp Aquos LC-15S1E 15 in. LCD Television
Televison & Video Logo
20 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
