Question about Refrigerators
SANTO K9 1240-41 FRIDGE SMALL FREEZER, NOT COOLING, COMPRESSOR SEEMS TO BE WORKING
    Top Expert:
  • Refrigerators Master
  • 28,938 Answers
Checking the temperature around the compressor, have you got temperature change on the pipes. If not it probably needs re gassing.
Posted on Feb 12, 2019
Testimonial: "will check thanks"
  • william welsh
    william welsh Feb 14, 2019
    so after checking they seem fine, the freezer part is working but not the fridge, can thast be the evaporator, , ? if so where would i locate it .thanks
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
electrodynam
  • 35 Answers
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Posted on Mar 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Posted on Jun 20, 2009
SOURCE: i accidently punctured a hole in a cooling tube in
Why not just use some JB Weld on the aluminum?
Posted on Jun 26, 2010
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
AEG OKO Santo not sure how old There is a hum
The hum on the motor can be faulty compressor motor or a weak capacitor that makes the motor to move slowly.But If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Sep 03, 2011 | Refrigerators
FREEZER COLD AND WORKING, BUT FRIDGE IS WARM AND WONT CHILL.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | AEG Santo 3888 KG8 Bottom Freezer...
My AEG Santo 75438KG Fridge Freezer has stopped cooling, freezer is working fine but as the fridge has stopped cooling the alarm keeps going off, I tried to arrange for a local fridge repair man to call...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | Refrigerators
I have an AEG Santo F/F. The freezer works but the fridge doesn't get cold ,even though its on max.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 13, 2010 | Kitchen Ranges
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Mar 16, 2009 | Refrigerators
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
