Question about Saeco Royal Professional Espresso Machine
Loud clicking and no coffee
I have taken the brew unit out, cleaned it, put it back together and it makes this horrifying clicking when someone tries to get a cup of coffee. It does not produce a cup of coffee and I end up with a lot of dry coffee grinds all over the brew unit. What is wrong and how do I fix it???
  • Saeco Expert
  • 223 Answers
Looks like your brew drive gears may be stripped. You should have a professional look at it because some must be causing the struggle to happen.
Saeco Service and Parts
Posted on Nov 28, 2007
Doesn't heat water sufficienty to make coffee
You may have l limescale. Run several limescale solutions through the machine (use delonghi's) and see if this makes a difference.
Also have you been cleaning and lubricating the brewing unit? if not take the brewing unit out. Take it appart and clean, then put back together. Make sure it moves smoothly, if not go to the hardware store and get some tap lubricant and apply to the o rings, then put back together.
Best of luck
Jun 27, 2014 | DeLonghi Prima Donna Avante ESAM6700...
I can not release the main component in my Saesco de luxe. Here a loud clicking noise when machine is turned on.
The loud clicking noise is a broken brew drive. This usually happens when you use the pre-ground button but put more than the level scoop into the brew unit. The brew unit can't compress the coffee and jams the brew unit which breaks the drive gears. Drive gears have to be replaced. I have some drive units complete.
Oct 26, 2011 | Saeco Magic De Luxe Espresso Machine
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Unit reads "Brewunit missing" I have taken it
Make sure that it is locked in the insert position before you try to install it. Push the press button and see if it clicks and the funnel moves. If you hear it click, then try to install. If it is already locked and ready to install, try this. Put the drip tray and dredge drawer in and close the door. Turn the machine on and see if you hear the motor move. If it does, then open the door and remove the drip tray and insert the brew unit. If you hear the click, then the dredge drawer.
If it doesn't click, then check the gear cog in the back and see where the large teeth are located. They should be at the 10:00 and 12:00 position. If they are not you have a broken brew drive. Sorry but that is a repair item.
Jan 10, 2011 | Gaggia Titanium Espresso Machine
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Gaggia Titanium dumps ground coffe inside unit
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Reads decalcify, brew unit missing- and wont make coffee!
Open you door on the right. Push on the upper left side of your brew unit and see if it will click. You have to push fairly hard towards the center of the machine. If it clicks the outlet pipe needs to be lubricated. The outlet pipe is the angled pipe on the top left side of the brew unit in the back. Lube the end of the pipe with food grade not food based lube.
Apr 27, 2009 | Saeco Royal Digital Plus Coffee...
My brew unit is stuck,
Try this.
You can enter a sort of diagnostic menu by pressing I believe the bypass doser and the medium coffee button together while you turn the machine on.
I forget which now, but one of the buttons will spin the brew unit one way, and another button will spin the brew unit the other way. The third button will activate the doser which makes a very LOUD clack noise.
You should be able to "wind" the brew unit manually this way in order to release it.
Good Luck.
Jan 22, 2009 | Gaggia Titanium Espresso Machine
Water does not blend with coffee
When you mount the grinder back, do you turn it so the red mark fit together?
Try to check the brewing unit, on the top off the brewing unit you will see a little pin. Take it out and make sure this is clean and put it back again.
Sep 02, 2008 | Saeco Incanto Classic Espresso Machine
Machine hot...screen says 'brew unit miss..'
Try to take out the brewing unit and make sure you press down the "press" button, you will hear a click. Now put it back again and make sure you hear a click again.
Let me know if this work.
Aug 18, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
137 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
