PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
IBM T40 Screen goes off after few seconds
By survival on Nov 26, 2007
I have IBM T40. When switched on it shows IBM logo and after few seconds it goes blank, completely blank though power stays on. Power stays on but nothing comes up on screen after showing logo. Plz helpppppppp. Cheers
Comments:
Nov 27, 2007
- Dear Ron, Many thanks for your time and solutions. I have looked up into the memory and the memory slot is empty. I have tried removing hdd and putting it back too. I also tried with another memory stick. But at the end of the day the final problem is it switches on show the logo or sometime even go to windows logo and then screen goes off. It seems that fan is running but nothing comes up on the screen completely blank. If switches on again quickly nothing happens on screen. One will have to wait few minutes and then switch on and then same problem display and screen goes off.
I very much appreciate your help. Many thanks.
Same Problem
May 23, 2008
-   My IBM T40, powers on fine, display goes blank totally.. sometime by holding "FN" and pressing "Spacebar" brings the screen or toggle FN + F7 but the screen does not remain. switches to blank, also tried connecting with other monitor, no luck... I took out the 512 RAM but no luck whatsoever. so annyoing, recently bought a new hard-drive.. please help.. akilamin@gmail.com -   akilamin
Dec 27, 2007
-   I am having the same problem with my T40. I tried hooking it up to an external display, and that functions in the same way. I boot up, both the laptop LCD and the external display work just fine, and as Windows is either starting up, or just after it finishes, both displays go blank.
Any other suggestions?-   t40downer
Best Solution
posted on Nov 26, 2007
Helpful)
Poohawk
Rank: Wiz
Rating: 84%, 252 votes
survival,
Here's a couple of things to try:
Power down and remove the battery. Leave it out until you are done with the following procedures. Remove the memory modules and put only one back in. Try to power up. If that works, replace the other one and power up. If that works, you're fixed!
If not, try to power up in safe mode and see what happens. If it comes up, try running diagnostics on the HDD. If that fails, try reseating the hard drive.
Let me know how you're coming along on this. May be able to come up with more ideas, if needed.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Was this helpful?
Yes
No
Solution #2
posted on Sep 30, 2009
Not Rated)
stevar
Rank: Apprentice
Rating: 0%, 0 votes
Well, being a techy I figured out this problem but not a fix. I have 3 T40 laptops with the same issue. One of them if you don't touch it it works fine. I probed around thinking the same are you , memory swaps and such but the problem seems to lie either on the motherboard or the CPU socket. When pressing my finger directly on the CPU it immidiatly freezes after making video glitches and garbage. It seems that the sockets become either faulty over time or the mother board has bad connections. I've tried swapping CPU's so that's not the issue. depending how much your CPU fan screws are tight will probably affect it's functionality. I just wish there was a real fix for it but it seems either mechanical or cold solder joints.
Comments:
Sep 30, 2009
- Bad CPU socket or solder joint. Trust me. I have two with those problems. Finger on CPU and caused it right away.
Was this helpful?
Yes
No
Solution #3
posted on Jun 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
no luck when i tried your solution..
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I am looking for a TRUE desktop-replacement. I am looking for a quad-core min 4. GB of DDR3... (More)
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
Aspire one has no monitor driver loaded...any idea where to download one
Answer
Screen suddenly went black, its as though its stuck in hibranation...laptop works if attached to a... (More)
Answer
How to take apart a compaq presario f500 laptop to get mother board out?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
