Question about Stoves Premier 900GRa Gas Double Oven
My oven point black refuses to power on.
Oven will not power on. checked fuse etc with no problems. has had intermitant power fault for appox 1-2 months. power off and on restarts oven and all is well. at the moment, when i power off the oven 2 red led's light and fade out. when i power up. no lights at all. any ideas?
  • 734 Answers
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter. Sometimes the power cord disconnects or burns at the appliance, if this is the case, the wiring and the terminal block must be repaired or replaced.
Posted on Dec 02, 2008
Fault finding
Check the fuses
Feb 05, 2018 | Zanussi Ovens
Think i blown a fuse/ where do i find the fuse
First check to see if power is coming from outlet, with meter or check breaker in panel box of main. Then you will need to be careful and check inside of oven power supply inside unit
Dec 22, 2007 | Whirlpool RBS305PDS Electric Single Oven
Oven not producing any heat
just the oven? then more than likely the element. if the stove eyes are not working as well, then your looking more at a sensor, thermostat, fuse, breaker, etc. almost always an element though
Mar 20, 2012 | Electrolux Ovens
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Neff u17 built-under causes fuse to blow on all the kitchen electrics a few seconds or minutes after the bottom oven is turned on. No problem turning top oven on. Have changed element in bottom oven with...
There could be a fault in the lower oven , or it could be overloading the circuit. add the watts of the two elements and divide by line voltage, this will give amps , now check the fuse rating amps , it must be higher than the oven. If that checks out ok the fault is in the oven.
Jan 03, 2018 | Neff U1721 Double circotherm Electric Oven
Oven not workiing
If it is a double oven, then there will not be a plug fitted to it.
It should be hard wired directly into a main 30 amp switch box
If there is no power at all, then it could be a faulty main switch unit, or
the fault could be at oven connector block.
You really need a meter to check for power, both at the switch box and the oven itself.
Another possibility is a fault with the timer unit on the oven itself.
Apr 05, 2010 | Neff U1421 Double circotherm Electric Oven
Complete power loss to Hotpoint electric oven
You need to ascertain that the oven is actually getting power.To do this, you are going to have to remove it from the housing and remove the terminal cover where the the cable comes in, and check for power there.
You may find that the terminal block has charred due to a bad connection and the wire has burnt away
If this o/k, and you are getting voltage there, then the problem is obviously within the oven itself, could be a timer fault.
If you have no voltage at terminal block, then the problem is between the terminal block and the main switch.
Hope this helps with your problem.
Dec 03, 2009 | Hotpoint Ovens
No clock, no power. Have checked fuse at point on
your fuses in the oven are bad it might have a fuse or a reset thermostat i need your model to tell you where to check and also make sure you have correct amount voltage in the wall outlet if its electric oven than you need 110 volts on each leg if its a gas oven than you need just 110 volts on one leg
Jun 07, 2009 | Ovens
Thermador oven sc302 no heat
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
3.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Mar 05, 2009 | Thermador C302U Electric Double Oven
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Stoves Premier 900GRa Gas Double Oven Logo
414 people viewed this question
Top Stoves Ovens Experts
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
