Question about Samsung Digimax S730 Digital Camera
Loud Beeping sound
I just tried to turn my Samsung S730 on and the green light flashed once and then the camera made a loud beeping noise. What is going on with it?It isn't even 3 months old yet.
  • 2,985 Answers
Re: Loud Beeping sound
This seems like Lens motor stall
Send it back
Posted on Nov 26, 2007
0 characters
3 Points
When i try to turn on my camera it attempts to open and instead makes a loud beeping sound and turns back off. i tried to recharge it thinking maybe the battery had died but this is not working.
Hi you have lens unit defective. your local repair shop would charge around $75 to 135 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Samsung DualView TL220 Digital Camera
Samsung S730 camera wont take photos with flash
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
When the power button is pressed, the screen lights up for a 1 or 2 seconds, makes a loud beeping noise then shuts down. I have put fresh batteries in it with no change.
make sure you are using the correct replacement batteries for the camera .check the user manual for the specified battery ,that could be a possible problem.
Apr 06, 2010 | Samsung S760 Digital Camera
The lens is not retracting
i have a samsung s730 and when that happens to me i put new batteries in it and it works
Apr 02, 2009 | Polaroid i830 Digital Camera
Need help
Mine does the same thing. It takes a few minutes to realize it has new batteries. lol. Keep trying, it will eventually come on.
Sep 09, 2008 | Samsung Digimax D53 Digital Camera
How to fix my camera
If your close to a Best Buy, you can take it to the Geek Squad and have them take a look at it.
Sep 04, 2008 | Samsung Digimax S500 Digital Camera
Samsung S730
no solution ours does this
waste of money return it if u can
Aug 11, 2008 | Samsung Digimax S730 Digital Camera
Beeping, bad noises, then turns itself off
If you have a retractable lens then that could be causing the problem. The beeps is letting you know that it's wrong and it shut off as a safe guard. So the noise you are hearing is the motor and gears for the lens.
Jan 27, 2008 | Samsung Digimax S700 Digital Camera
Can't get the camera to Flash
EXACT same problem. Tonight I tried to take a picture and heard a loud pop sound but I didn't think it was my camera... anyway it took the picture but didn't use the flash. Later, my sister went to take a picture with the flash and it made the same loud pop noise and now the camera wont work if the flash is on.
Jan 19, 2008 | Samsung Digimax S630 Digital Camera
If you don’t find a solution you may want to try He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Jan 19, 2008 | Samsung Digimax S730 Digital Camera
Samsung Digimax S730 Digital Camera Logo
81 people viewed this question
Top Samsung Digital Cameras Experts
Are you a Samsung Digital Camera Expert? Answer questions, earn points and help others
