Question about Elgin Watches
How much is a mens elgin japan movement pc21j stainless steel case back. 91-799 Battery sr626sw
    Top Expert:
  • Elgin Master
  • 58,556 Answers
FIXYA NOT BEING A RETAILER OF BATTERIES HAS NO CLUE GO SEE A WATCH REPAIR SHOP
Posted on Feb 12, 2019
  • 4102 Answers
SOURCE: open a watch
Hi, this is easy to do what you need is a sharp knife then the back of the watch will have a case on it smaller than the watch you will see its raised and has an edge running all the way round. Sometimes their is a tiny recess running along the top or bottom of this cover this is to put knife into to pry the back off, not all watches have this. If yours dont then get sharp knife and pry the cover off from either the top or bottom it can be tight but get the knife so your putting pressure on to lift the cover up. The cover is only pushed in and it clips in so their is nothing holding it down.
Just keep prying it with a thin sharp knife untill the back lifts off it shouldnt be that difficult but just use thin knife and keep working it so as to lift the back cover off the watch.
This will give you access to the battery and once replaced the back just pushes on by hand push it on hard as this seals it from water and dust.
Posted on May 15, 2008
slp11508
  • 43 Answers
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Posted on Jan 05, 2009
escapement
  • 2338 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
  • 2501 Answers
SOURCE: Swiss Legend Chronograph Stainless Steel Case- how
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Posted on Feb 25, 2010
CaptainHawk1
  • 345 Answers
SOURCE: need to add links to
That's the battery number for the watch also known as the #377. It's the most common watch battery in the world. Your model number is located at the bottom of the dial (face) below the six-o'clock position. You will need a 10 power jeweler's loupe or magnifying glass to see it and read it. Jot down the number and contact Elgin directly (MZ Berger Co,) for the extra links.
MZ Berger.
Posted on Jun 20, 2011
How much is a ELGIN men's Diamond Base Metal Bezel FG007 017 PC21 Japan Movt stainless steel back wrist watch worth
probably not as much as you think it is worth. There are to many varibles to consider value. An item is only worth what another person is willing to give you for it. If you truly want its value, go have it appraised. That will cost you to get a qualified appraisal.
Apr 24, 2016 | Elgin Watches
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
Need to add links to a new Elgin watch band. The number on back of watch is SR626sw
MZ Berger.
Jun 20, 2011 | Watches
Swiss Legend Chronograph Stainless Steel Case- how to change the battery
Feb 24, 2010 | Swiss Legend Chronograph Stainless Steel...
I don't know how to set my watch . It is a japan movement watch #sr626sw
626sw is the battery # you can send a picture of the watch I may be able to help you since I worked with watches for 19 years.
Nov 18, 2009 | Watches
Watches Logo
22 people viewed this question
Top Elgin Watches Experts
NOEL
NOEL
Are you an Elgin Watch Expert? Answer questions, earn points and help others
