Question about Dishwashers
Whirlpool dishwasher mod# du1048xtpq4
It will fill on all cycles and once it is filled it clicks and sometimes hums, but will never start to wash. any help?
  • 2 more comments
  • beerstud Nov 27, 2007
    Whirlpool du1048xtpq4 about 1 1/2 years old
  • beerstud Nov 30, 2007
    Whirlpool DU1048XTPQ4 about 1 1/2 years old.....
  • David Ritchie
    David Ritchie Mar 24, 2009
    I have this same model, same issue. Model # is DU1048XTPQ4
    SN 2708474. I pulled this out, there was stuff in the impeller/chopper (wire and a small piece of glass). Could not figure out how to get the motor loose from the sump, so I cleaned it out the food grinding area and confirmed that the motor and blade would turn to see if the shaft would turn. Resistance was asymmetric between the center tap of the drive motor to the outer connectors (5 ohm from center to one side, 9 ohms from center tap to other side). Motor start capacitor checks out fine on DVM (26 uF). Drain motor works ok, but main
    motor hums and I can feel vibrations when I touch the frame.
    I am guessing that I am going to have to pull the sump again
    and pull the main motor completely out (at least now I don't think I need to pull it out from under the counter..). Any suggestions? Also, is their anyplace to pull the Whirlpool tech
    sheet for this? I don't seem to have one on my dishwasher (I did not look under the insulation blanket however).
    -- Dave
  • 213 Answers
Whats the model number?
Posted on Nov 27, 2007
My Whirlpool dishwasher GU2400XTP fills with water and pumps out properly but does not wash. The pump hums during wash cycle
is there food particles clogging the water intake for the pump or it could be that the motor is seized from bad seals if that is the case then you may want to see if you can get a new pump motor
Feb 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Starts but will not go into wash cycle
My solution to this problem was to simply unplug the power from the wall for a few seconds...plug back in, try to cycle again and the wash cycle starts fine now. May have been caught in a cycle loop or something. Any way this solution worked for me hope it works for someone else.
May 23, 2010 | Whirlpool GU2400XTPS Built-in Dishwasher
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
LOUD HUMMING AFTER WATER FILLS AT START OF CYCLE
Sounds like you have something in the sump/motor. I could lead you through it on a chat session but too much just to type. Let me know if you would like me to do so.
Mar 04, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Oct 25, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
244 people viewed this question
Top Dishwashers Experts
