Question about Royal Office Equipment & Supplies
I have my late-mother's Royal Companion. The the right-hand wheel on the roller is broken; and half of it is missing. Is there a place to purchase that wheel?
3 Suggested Answers
SOURCE:
SOURCE: Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Posted on Jan 27, 2009
SOURCE: Upper rack roller axles are brittle and 1 has
Our upper wheel failed. It is part of the huge assembly called the "Rack Adjust" on our model # PLD4460REC Frigidaire Dishwasher and cost $88 to $120. Hey.. thanks to the guy above I was able to fix my machine without spending to much!! for a huge part when all I needed was the upper wheel. the part # for the upper wheels is = PS976006 and is for another model dishwasher (Sears located it for me first.. without trying to make me buy the huge assembly) but might work... I will order and give them a try. The model # referenced about seems to be incorrect... We used model # PLD2855RFC1... as google helped us fill in the missing part# letters. I asked frigidaire... why they encouraged customers to borrow this small part from the store display.. why not just sell it!! .;)
Posted on Jun 30, 2012
I have an older royal orca 9512x shredder that I purchased at staples....recently it wouldn't work...I found out that the plastic switch that triggers the shredder fell off ...a small projection of...
screw a small screw into the piece in the back right corner of the basket that the shredder fits on. This will adjust to the height needed to make the shredder run.
Jun 17, 2011 | Royal 15MX Shredder
Squeaking noise from roller that turns the belt. a film like substance seen right hand side on the roller
you can purchase a new roller from fitnessrepairparts.com or treadmilldoctor.com it needs replaced. The plastic is what keeps the belt in place.
Aug 12, 2010 | Icon HealthRider H 120 Treadmill HMTL39906
Aug 02, 2010 | Frigidaire PLD4460REC Stainless Steel...
The roller wheel on an HP mouse works just fine for me,but not for my 89-year old mother. She is weak and has a bit of a tremor. Can that be affecting it? I have tried useing the roller wheel with the...
i purchased the rat 9 wireless mouse.the scroll wheel is very sensitive,so may be ok for your mum go to any computer shop and ask for a demo with your mum to see if it is better for her hope this helps
Jul 29, 2010 | HP Keyboard & Mouse
Brushes won't turn and vacuum will not pick up sprayed cleaner
There's a Capt. Obvious fix to check before you go any farther. Like many vacuum cleaners, the brushes on the Bissell carpet cleaners, by design, only spin when the handle is not locked in the upright position, so be sure to plug it in, turn it on, and depress the foot pedal to lower the handle while watching the brushes one more time to be sure that the fix isn't that easy.
If the brushes still won't spin with the handle in the unlocked position, lift the handle back up into the locked position, power off and unplug the Bissell, and look down and see if either of the two belts that make the brushes spin are broken, as a broken belt, or a belt that's come off the track, is the next most likely problem. Both belts must be unbroken and in the right place for the roller brushes to spin.
These belts can be seen in the clear plastic pieces on either end of the roller brushes. If you're having trouble locating them, **with the Bissell unplugged so the brushes won't suddenly start spinning and hurt your hand**, try spinning the brushes with your fingers while watching for the belts. They're black, about the thickness of two quarters, and the bigger one of the two (on the left end of the roller brushes, as you face the front of the Bissell), is just big enough to fit around both roller brushes. The smaller belt, goes around the back roller brush on the right and to a smaller cog wheel behind it. If you see a broken belt, or a belt off the track, that's your problem.
Here's a video you can watch for free on Bissell's website that tells how to replace a belt. I'm sure the belts can be ordered online somewhere or found at some Bissell dealers or repair shops. Note, again, the two belts are different. If only one is broken, be sure to order the correct one.
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp
If the belts are intact and in the right place, does the metal cog wheel behind the roller brush right turn when the Bissell is on and the handle is dropped? If not, then the motor that turns that cog wheel must be burned out.
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Apr 09, 2008 | Office Equipment & Supplies
Tried solution for printer unable to initiate
This is related to the paper feed roller:
Check encoder disc if it is stained with ink or broken (its the round foil disc which is fixed on one of the three white big gear wheels on the left hand side). It should turn around without any scratching sound!
Check if another gear wheel is broken (right hand side behind the purge /parking station). Here you will find the gear box which is shifted by print head (little white plastic coming out of the metal plate between purge station and absorber box)
Pull out the paper tray and try to turn the paper feed roller by hand. You can reach it when seeing from bottom without the tray.
Dec 07, 2007 | Brother MFC 210C All-In-One InkJet Printer
49 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
