Question about Sanyo Refrigerators
My Sanyo standing freezer door fell off because bottom door hinge broke.how can I fix it pls
    Top Expert:
  • Sanyo Master
  • 6,073 Answers
Replace the hinge.
Posted on Feb 11, 2019
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
  • 52 Answers
SOURCE: Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 26, 2009
  • 6 Answers
SOURCE: frost free freezer with ice in the bottom and
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Posted on Jul 11, 2009
  • 71 Answers
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Posted on Oct 03, 2009
  • 234 Answers
SOURCE: I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Posted on Dec 27, 2009
WHIRL POOL STAINLESS STEEL FRENCH DOOR- BOTTOM FREEZER MODEL NUMBER GI5FSAXVY
You should be able to buy replacement stripping at any local hardware and furniture store.
Sep 16, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
E522B - About 6 mths ago, a the clip on the bottom hinge of the freezer door broke into two , depositing the one end on the kitchen floor . Fridge seemed to operate OK regardless. Today, the same clip on...
I know this thread is super-dead. Mine broke off a while ago and it means the door doesn't stop until it is 180 degrees open. The bit that broke off is the door-stop part of the lower hinge.
I just put this here in case it helps someone else stumbling upon this thread as I did.
As far as I can tell, the part is available somewhere. I am off to find out where, next...
Aug 14, 2012 | Fisher and Paykel Active Smart E522B...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
How do you reattach the door to the stainless steel mini fridge? I kinda hit it and it fell off.
you will need to lift the cover from the top hinge loosen the approx 3 screws holding the hinge on do not remove completely just enuogh to allow door pin to be reinserted in the hinge then close door and tighten hinge
Jan 03, 2011 | Sanyo Refrigerators
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
Freezer door stop broke off
Take your remaining pieces to a Servall store. They carry parts for all appliances or do an internet search.
If you can not reach the parts easily, try to get a serial number and model off the Fridge and check the internet for a Viking dealer near you.
Sep 18, 2009 | Viking VCSB423 Side by Side Refrigerator
Hing and plug fell out and now Ice maker door stays open
It just un-snaps. Pry gently along the top or bottom edge and work it off with a plastic putty knife. Snaps pretty good and sounds like it is breaking.
Eric
Jul 16, 2009 | KitchenAid KSCS25FKSS Side by Side...
Frost build up Jenn-Air JFC2089HTW
have you tried to re align the hinges? is the hinges broke?
Jun 25, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
Kenmore Freezer display alternating between temperature and CE
Our techs at our shop could not figure this out either but since the Kenmore was made my Frigidaire and we were Frigidaire warranty we called them.
This is what they had to say:
The code stands for bad wiring. In other words, there is a wire broke, corroded, etc. The wire problem is normally near the bottom hinge. The solution is to find the problem wire or if its in the door replace the entire door. Our service guys had found the problem wire near the alarm's power source.
Hope this helps!
Jan 01, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer Door Fell Off
Generally, door hinges have a post on the door part and a hole in the box part.
In fairness to Sears, you caused the problem.  Ice is caused by failure to keep the door closed, open containers with damp product inside and the like.  Forcing the doors will cause them the distort and that's what you did.
You may have to pay a visit to Sears and look at a floor model to see what it looks like.  Take a camera.
Nov 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
22 people viewed this question
Top Sanyo Refrigerators Experts
Marvin
Marvin
Bailey's...
Bailey's...
Albert Nairn
Albert Nairn
Level 1 Expert
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
