this proplem have many causes follow this steps to dipose of it first check that your drum is good sconde when machine overflow toner and no cleaning in machine due to that and software has many proplem sluggish if yo turn off machine and unpack ram in interface unit and pack again it will disappear temperorly for while and will come back
first stip try to reset machine yellow 107 and try to unpack drum from his place you will see wire who catch drum and rolling it ok unpack back cover of machine and unpack solid circulies which make drum balanced then yo will see pin with sprin this may be compressed need get back to normal position
This product can be configured to use a metered or non-metered Toner / Print Cartridge. A non-metered machine requires a non-metered cartridge be installed to operate, while a metered machine can accept both a metered or non-metered cartridge to operate.
Make sure the correct cartridge is used for the machine. If you are receiving metered print cartridges but the machine will not accept them, contact your reseller or supplier to ensure that your machine is properly set up as a metered machine, and that the metered PIN has been entered
Make sure you don´t have any stickers on the toner box.
If you sure all paper and stickers are out then reset the nvm values from the device in order to reset the printer information.
