Question about Cameras
I have a aquaveiw scout that the camera cable is broke right where it connects to the back of the unit can I get both parts to fix it
  • 864 Answers
Posted on Feb 11, 2019
  • 205 Answers
SOURCE: motherboard, cooling unit connection broke
As Eblackadder says, you probably need a new board, but since that's the case you can take the attitude that you have nothing to lose.
If it were me, I would look very carefully at the motherboard around the socket to see if you can drill some small holes without hitting a metal trace. You will really be gambling here because these boards have metal traces embedded inside the board that you may not be able to see.
Assuming you can find a few spots where you think drilling a small hole is possible you could then use zip ties to pull the heatsink assembly down tight to the processor. I would use very small zip ties. Since these are typically not very long, you can chain a number of them together.
Best of luck.
Posted on Nov 28, 2007
  • 346 Answers
SOURCE: cable connection broke
it can be repaired.otherwise replace tuner
Posted on Dec 22, 2007
SOURCE: Cable connection on 42'' VIZIO
bring it to a repair shop are us the yellow red and white cable
Posted on Feb 08, 2008
  • 18 Answers
SOURCE: cable connection in back of tv broke.
part name -tuner -u can buy from electronics spare part market
Posted on Dec 26, 2008
jose_v17
  • 229 Answers
SOURCE: Cable connection broke on back of tv
YOu will need a box that will convert your coaxial signal (cable) into a another using either Composite (RCA wires) or component (Yr,Yb, Yg) outputs. Your local radio shack should be able to accommodate you
Posted on Apr 01, 2009
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
Bushnell Yardage Pro Scout
If it's like the one in the picture they don't have parts anymore. If it's the small unit call 800.423.3537 and ask for Michael. He can and will fix it. Alignment is 30 bucks, Lcd is 15 bucks and all other maintenance and adjustments are 15 bucks. Now this is half the price of a new unit, just to repair this one......Think about it.
mr tech geek
Jul 12, 2009 | Bushnell Yardage Pro 800 Compact...
Nikon d90 lens plastic mount broke
I feel for you. exactly the same happened to me but i was looking to upgrade lens so i used it as an excuse.the piece is called a bayonet. what lens is it, is it the kit lens. my lens was unfixable so  am afraid as the mount is plastic the whole lens is a right off, if it was a metal mount it would be worth fixing. sorry
Mar 13, 2009 | Nikon D90 Digital Camera with 18-105mm...
How can i fix a sanyo VPC-E870 screen by myself'
THE SCREEN YOU REFER TO IS ACTUALLY PART OF A UNIT CALLED THE LIQUID CRYSTAL DISPLAY AND HAS TO BE REPLACED AS A UNIT. FINDING THE PART WILL BE VERY HARD AND CHANGING IT IS A VERY TECH HEAVY JOB! YOU'RE TALKING MICRO CIRCUITS AND TINY PARTS. PLUS, WHEN THEY BUILD THESE CAMERAS, THEY REALLY DON'T EVER PLAN TO OPEN THEM UP AGAIN TO "FIX THINGS" IF YOU GET THE IDEA. I KNOW THIS DOESN'T HELP, BUT THERE ARE PLACES THAT WILL FIX THIS, BUT THE COST IS STEEP AND YOU CAN EXPECT TO BE WITHOUT YOUR CAMERA FOR AT LEAST A MONTH OR MORE, BECAUSE THEY FARM IT OUT ALSO TO AN OVERSEA REPAIR UNIT, MOST LIKELY. SO, IF MONEY IS IMPORTANT, THE BEST OPTION IS SPRING FOR A NEW CAMERA. SORRY, BUT I HATE TO SEE YOU SPEND LOTS OF MONEY ON A REPAIR LIKE THIS.
Oct 25, 2008 | Sanyo VPC-S7 Digital Camera
Bushnell trailscout model 11-9900
forgot my pass number on my bushnell trail scout 119900 plese assist
Oct 17, 2008 | Bushnell Trail Scout 11-9830 Digital...
USB cable broke inside camera port
Buy a portable card reader. Insert in USB port. Insert your card and download. You don't need a cable then.I just bought one for $10.49 with a $6 rebate from Radio Shack.
Nov 08, 2007 | Vivitar ViviCam 5386 Digital Camera
LCD Screen goes blank after opening up
I actually have several of these cameras and have seen this happen many times with this model. The ribbon cable that goes from the body to the LCD tears in the same place in all of my experiences. If you look at the hing area, you can see the black coating on the ribbon cable between the body and the LCD. The top edge of this cable tears right where it enters the LCD component. If it works when only 1/2 way open, it's just a matter of time before it totally stops working...the damage has already begun. A replacement LCD runs >$100. Instead, I search e-bay for parts cameras. Just make sure that the description doesn't say that the LCD is bad.
Taking apart the camera isn't all that hard. Start with the e-bay parts camera just in case something goes wrong. Take off the lens cover (the lens actually stays attached to the camera for this entire fix) by removing a screw on the bottom, one just under the eye piece, one inside the LCD door area (near the top), and one inside the tape area...the one closest to the front of the lens. Then, the lens cover slides forward. Once you get it moving forward, extend the eye piece and the lens cover comes right out.
The 2nd step is to remove the LCD. The easiest fix is to remove the entire left side (LCD and SD flip cover). This is done by removing the 3 screws on the bottom (careful, 1 is smaller than the other 2), the screw in the battery area, a screw near the front of the lens, and 2 screws near the top (one above and 1 below the lens). Once the left side is free, tip it forward, exposing the 2 ribbon cables. The larger one is the LCD. Disconnect it by simply flipping the grey bar where the ribbon cable connects to the body up. The ribbon cable should come out with no effort. The other, smaller ribbon cable is the speaker and the "LCD is Open/Closed switch". Be careful with this one. Hold the white connector in place against the body (I apply pressure using a small, flat screwdriver). Pull the ribbon cable out of the holder at the body with your fingers (it should require only a moderate amount of force). If the white cable connector comes off with the cable, you're in trouble...the wires are extremely thin and difficult to get back in the right place...but it can be done.
Once you've removed the left side portion, do the same with the good LCD. Reconnect everything in the reverse order. I use a small needle nose pliers to put the small ribbon cable back into the connector. The larger one just slides in with little to no effort. Lock it in place by tipping the locking back back down. Once you've connected these 2 cables, you can carefully put a battery in and test that it works. If all goes well, remove the battery before continuing to put it back together again.
When you're done, put the parts camera back together again and keep it. You may need it for the lens assembly (I've had grease inside my lenses at times and the front lens can scratch easily, so a replacement is good to have around).
I've tried replacing just the ribbon cable, but getting it out of the LCD isn't worth the effort since finding a good cable usually means that you've also found a good LCD for the above proceedure.
You can find the repair manual complete with exploded views at http://www.eserviceinfo.com/download.php?fileid=27179.
Oct 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
Lcd dark
Use an eyeglass screwdriver to remove the back half of the case. (6 screws, 2 screws each on sides and bottom) When you remove it, the ribbon cable for its buttons comes out just by pulling. You now see the LCD (which is fine), its cable connection (lower right), its power connection (two wires on right). Either these wires have come unsoldered (easy to fix without microsoldering capability) or some part of the power supply for the LCD backlight is bad (very hard to fix, you probably need a new motherboard). When you put the case back on, first you have to plug in the ribbon cable - first open the tiny black plug lock out and around to the left, put the cable all the way in, then lock the black part back right and in. Screw the case back on and you're fine.
Jan 14, 2007 | Casio Exilim EX-Z750 Digital Camera
Flexible circuit board
Camera manufacturers are renowned for not releasing parts manuals or service manuals so the best bet would be to use another camera to take some shots of the part you need and email them to Sony. They'll figure out what you need. Unfortunately some of these flat ribbon cables are terminated within a particular part and so you may have to be that part with the cable attached. BMW
Jun 26, 2006 | Sony Cyber-Shot DSC-F828 Digital Camera
Cameras Logo
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
