Question about Samsung Refrigerators
Samsung model RS263TDBP/XAA 9 years old: Humming noise on fridge side, about 3 feet from floor. Occurs when door is closed. How to fix? What parts? How to access? Can a novice fix this?
I unplugged for a few days, took off the lower shield on the back, cleaned the fan in this location, and plugged back in. This week it started making noise again. Sounds like the noise is originating from about 3 feet up from the floor on the fridge side. There is nowhere on the back to unscrew to check.
  • Chris Huff
    Chris Huff Feb 11, 2019
    It could be a defrost problem that causing ice to build up and obstruct fan
    Top Expert:
  • Samsung Master
  • 6,073 Answers
Sounds like the evaporator fan.
Posted on Feb 11, 2019
SOURCE: Samsung side by side refrigerator not working
I am somewhat of a fix-it guy and here is my take....I also have the same refridge with other problems, and have done alot of research and discussions with the local repair techs and Factory rep. Here we go: The Samsung models are very prone to problems arising from power fluctuation's that fry the motherboards. One problem may be that the defrost circuit fails and the unit freezes up causing a lack of cooling and loud banging of the compressor. To run a diagnostic of the unit, you need to press both power freeze buttons for 10 seconds beeps will sound and release, the dashes on the display showing if any circuits are bad.(self diagnostic) This is what the service guy will do then come in with the part and replace. With a bad board, the diagnostics reveals no problem and the service agent will just start replacing parts, at your expense! Also the part #'s will show discontinued but they just changed parts #'s.. Be careful, my dealer said all parts were no longer available....he was wrong! Motherboards are a bear, I believe my model has 3!Most techs are not familiar with Samsung and will not be able to correctly diagnose the problems, mine came out and said it! "We do not Know and the factory will not give us any idea what the problem is" We're sorry! That was 3 month ago, and now I have a beautiful yard fixture! a $1400.00 yard fixture!! hope this helps someone..
Posted on Sep 06, 2007
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
BNewberry
  • 93 Answers
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Posted on May 15, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
jumptrout51
  • 3361 Answers
SOURCE: Not cooling, unpluged for few hours, it worked fro couple of weeks, stopped cooling again 2 days ago, I unplugged for few hours, It is working now
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
Posted on May 26, 2009
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
My Samsung Refrigerator is making a noise that sounds like an old style door bell. It a loud buzz that occurs several times a day. Do you have any ideas?
User manual and parts list and diagrams.
SAMSUNG Refrigerator Parts Model RF217ACPN XAA
Your refrigerator has at least three motors with fans in addition to the compressor motor. The one most suspect is the one that passes air from the freezer to the refrigerator.
samsung refrigerator noise YouTube
Oct 19, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Samsung side by side, three years old, model #RS263TDBP...freezer is working fine, fidge is warm. What should I check first and how? Thank You!
Check and see if you have ice forming on the water tank if you have a water dispenser. The tank is usually behind the bottom drawer of the fridge compartment.
If you see ice then it is another sign that the defrost coil needs replacing. Samsung units are notorious for failing defrost coils.
Have a look here on YouTube - https://www.youtube.com/watch?v=DO2wDd16OkA
It shows where everything is. You can get a repair kit and it is relatively easy to replace - just take it slowly and you'll be fine!
Before any repairs are done, you will need to defrost the whole unit - switch it off for 2-3 days until there is no sign of ice.
Hope this is of some help
Sep 28, 2014 | Samsung RS263TDBP Side by Side...
Samsung RS263tdbp fan making noise when closed and opened refrigerator doors
is there a build up of ice around it or is the fan blade bent and hitting something, otherwise u may have a bad motor in the fan going out
Jul 17, 2014 | Samsung RS263TDBP Side by Side...
How to Test the Fridge Fan on Samsung Refrigerator Once you have the fan motor out put a drop of machine oil in the bearing caps. That will stop the noise.
Feb 14, 2018 | Refrigerators
Door does swing closed so it remains slightly open about half the time when the last person could have sworn they closed it. Hubby tried to adjust hinge but it did not make a difference. The fridge is only...
There should be a way to level the feet of your fridge so the door swings closed by itself. Check the user manual that came with your fridge for advice on how to do this on your fridge, as each make and model of fridge differs. This technique to level a fridge on the floor is generally necessary because the floor where the fridge is placed is unlevel, and it does not imply any fault with the fridge itself.
Jun 08, 2010 | Kenmore 53642 / 53644 Side by Side...
Our kenmore fridge is really loud and as the mtor keeps comming on to keep it cool. It is a humming whining noise. The fan at the bottom back side of the fridge does not seem to be the problem. I think it...
simple answer to this is to get a spirit level and make sure it is square to the floor,in all directions.and put anti vibration pads under the feet.
Another "fix"is to replace the mounting rubber washers(if you can find some)for the compresor.have known people use rubber bands(NOT ME.)
lastly do make sure its not leaning against a wall.
or touching anything else(it will amplify noise).
Mar 31, 2010 | Refrigerators
Fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Dec 18, 2008 | Dishwashers
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
24 people viewed this question
Top Samsung Refrigerators Experts
Paul
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
