Question about Electrolux Refrigerators
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
SOURCE: Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 04, 2009
SOURCE: Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Posted on Aug 13, 2009
SOURCE: Water setteling on bottom of freezer side and
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Posted on Sep 14, 2009
SOURCE: Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Posted on Apr 19, 2010
Hello friend, thanks you for your post!
It sounds like a possible leak within your water line or water filter and that is what could be causing your Electrolux refrigerator fan to freeze. I would recommend having a professional come out to properly diagnosis your refrigerator.
The leak could also be within the cabinet and a technician would have the appropriate tools need to locate the cause of the leak. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux EI26SS55GS Stainless Steel ...
Jul 31, 2012 | Electrolux Frigidaire 16.7 cu. ft. Upright...
Jul 31, 2012 | Electrolux Frigidaire Professional Series...
Jun 22, 2012 | Electrolux Freezers
Apr 25, 2010 | Frigidaire FRS23KF7AB Side by Side...
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Sep 13, 2009 | Refrigerators
May 07, 2009 | Electrolux Refrigerators
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Oct 08, 2008 | Electrolux Refrigerators
26 people viewed this question
