Question about Oregon Scientific Audio Players & Recorders
My Oregon Scientific STARCK clock and temperature etc. has a very dim display and I don't know if there is any way of making it brighter? I have set the adjustment to the brightest setting. Thank You
SOURCE:
  • 76 Answers
SOURCE: Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Posted on Jan 07, 2007
SOURCE: Manual for oregon scientific rm313PNA
http://pdf.smithgear.com/RM313PNA.pdf
Posted on Dec 20, 2009
  • 3 Answers
SOURCE: Oregon Scientific Stark clock resets itself to PST.
-Press SELECT once and time number should flash.
-Press and hold SELECT and it will enter settings mode for the clock.
-At the bottom of the screen next to the moon phase you should now see PST time zone.
-UP and DOWN keys will change the time zone.
-Press SELECT and other clock settings can be changed.
Posted on Dec 21, 2009
  • 3 Answers
SOURCE: Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
SOURCE: Delphi XpressRC XM Radio backlight problem
Same thing happened to mine until it permanently went dark - no brightness. Problem is with the LCD display that is defective. As this model does not have a separate filament bulb unlike the non color model, it cannot be repaired. Likely too expensive to replace the color LCD display if avalaible. Next one I buy will be a non color version which has separate bulb.
Posted on Mar 24, 2010
Tip
How to set the alarm plus any other settings on the Starck PSMO2A-Y
To SET anythything including the ALARM do the following for each. This example is for the ALARM.<br><br>1. Press "Select' once until time starts blinking. <br>2. When you get to the Alarm time and it it blinking, Hold down "Select" for 2 seconds to put it into "Set" Mode. You know you are in the right place if only one of the numbers in the alarm time is blinking. From there use the "up" and "down" to select your time and tone! Enjoy! <br><br>For a full manual go too: http://www.retrevo.com/support/Oregon-Scientific-PSM02A-manual/id/423ag522/t/2/
on Aug 26, 2013 | Oregon Scientific Starck Medium Visual...
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
don.miller60@outlook.com
Nov 30, 2015 | Bose Wave Radio
ONLY SHOWS INDOOR TEMPERATURE DOES NOT SHOW OUTDOOR TEMPERATURE
I have a similar device and the instructions say to remove batteries from both units and wait for 10 minutes without pressing any buttons before installing batteries first in the remote unit then the indoor unit. The outdoor and indoor units have to "talk" to each other before getting in the mood to display temperatures.
Feb 03, 2013 | Oregon Scientific Wireless IndoorOutdoor...
I have a scientific radio controlled clock - modelRM913TCN and I don't have a clue how to set it
Your device can set the clock automatically by means of receiving radio signal for synchronization.
But if you want to know it I give you this link from where the complete user guide can be download for free:
http://www.cintelcorp.net/oregon-scientific-rm913tcn-radio-controlled-clock-with-backlight-manual
Using this link you have to wait a little bit and copy a security code then you can start downloading.
Good luck.
Thanks.
gylacz
Jul 14, 2011 | Oregon Scientific Audio Players &...
Jul 26, 2009 | Oregon Scientific Starck Large Music...
Feb 08, 2009 | Oregon Scientific Starck Large Music...
Dim Digital Display
Jan 06, 2007 | Frigidaire FEF326 Electric Kitchen Range
44 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Gyula Lacz
Tom Chichester
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
