Question about Refrigerators
Clicking noise with NEC FR-236 fridge. Still keeping cold temperatures but compressor is hit
The fridge has been starting to make and now more frequent clicking noises seemingly from the compressor at the back. These are the things I've checked 1) I have removed the starter relay and shaken it but do not hear any rattle. There are no burn marks on the start relay and overload device. Both are clean. I've disconnected and reconnected and have same issue. 2) the compressor is very hot when the clicking occurs. Also, this is more frequent during the day than at night where the air temperature is cooler ( I.e. longer intervals) 3) one major difference is that both the freezer and the fridge is keeping the temperature as per normal, at same temperature before the clicking started. 4) the unit inside is not very dusty. Nothing that should cause overheating. I'm not sure what to do here other than just blindly replace the overload device and start relay and hope for the best. Unfortunately I wasn't able to test the amperage (?) for the connectors as I do not own a volt meter and this fridge doesn't seem to have a condenser fan at the bottom of the unit next to the compressor.
    Habit-Forming:
    New Friend:
  • 102 Answers
Compressor is losing you. a good Replacement will do
Posted on Feb 11, 2019
suisboy
  • 175 Answers
SOURCE: GE refrigerator profile arctica Not cooling frige or freezer PTS25LBMARBB
well if the compressor dont have power so how could it work or cool?
Posted on Jan 16, 2008
  • 1462 Answers
SOURCE: Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Posted on Jun 25, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore Fridge; started w/clicking noise, not it's no longer cool
The noise is the overload. The compressor is trying to start and because it cannot start the overload clicks when the circuit is broken to compressor. Yes the problem could be the relay. The relay should be beneath the cover where the wiring goes into compressor. It could also be the start capacitor that the relay uses to start the compressor. When the thermostat tells the compressor to start the relay momentarily come on with stored voltage to bump start the compressor. Once the compressor starts the relay opens to prevent the no longer stored voltage from going to compressor. In short we need to unplug the refrigerator and open back near compressor to view and remove the cover that the wires go into. Mark the wire connections and see if you can get one of your local refrigeration stores to check the capacitor and start relay. You can do all of these by purchasing a three in one start capacitor and relay designed for you refrigerators size. But before you do all of these things get back with me so we can test the compressors windings. Let me know, Thanks, Sea Breeze
Posted on Mar 23, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Posted on Jun 28, 2009
NEC FR 405 Fridge/Freezer
Hi Sound like your freezer needs a new thermo switch. The switch regulates the temperture and turns it on and off. Replace and your good to go.
Jan 21, 2014 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
The fridge or freezer won't keep it's cold temperature. Air that comes out isn't cold either. There is a noise like a fan is working however.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | GE Refrigerators
THE FRIDGE DOES NOT START.THERE IS TICKLING NOISE NEAR COMPRESSOR OR TIMER
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 21, 2010 | Daewoo FR-094R Refrigerator With Ice Box
Kitchenaid Refrigerator
Built in KitchenAid means your fridge is in the price range of $ 10,000/=.
Most likely the compressor and condenser on the top of the fridge. That is why you get the ringing noise. May be compressor not starting properly. Starting device issue or compressor seized.
Shut off the fridge and call a local service guy or Whirlpool Corporation. No time to test this and that. Your fridge worth $ 10,000/=. Don't be penny wise and pound foolish.
Oct 24, 2017 | KitchenAid Refrigerators
Fridge keeps making "clicking" noise and will not get very cold
the clicking noise is probably the unit trying to start but it cant because its too overheated,try turning it off for about 30 minutes to cool the compressor down,then put the thermostat at 3 for the fridge and not the coldest for the freezer and leave it there for a few hours to stabalize the temperature and see what happens.
May 09, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Apr 27, 2009 | Refrigerators
WHIRLPOOL REFRIGERATOR DISPLAY FLASHING AND NOT COLD
Before replacing the board, you should try replacing the starter relay on the compressor, presuming the clicking is coming from this area? The flashing could indicate that the fridge is out of setpoint temperature range and is an alarm to this fact. If the clicking is coming from the board area, it is a relay trying to come on. Hope this helps.
Mar 20, 2009 | Refrigerators
Clicking noise from JCD2295HES side-by-side refrigerator
sounds like a compressor relay check with maytag mightr be one of the recall ones
Mar 17, 2009 | Jenn-Air JCD2295HES Side by Side...
Fridge has stopped working/getting cold
check the relay, the clicking noise is your overload tripping out on overload, the run winding of the compressor are not coming on line, if your relay is good, the ohm out your compressor.
Feb 20, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
