Question about Kenmore Washing Machines
Kenmore washer 100 series owner's manual. Looking for the water level switch located
  • Cindy Ball-Rose Oct 09, 2019
    Looking for level switch. I can't seem to fill it all the way up
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I do not know about a Kenmore but all the washing machines I have taken apart have a pressure switch located near the top just under the lid. as the water fills the machine it also fills a plastic pipe which is connected to the pressure switch.
Posted on Feb 10, 2019
SOURCE:
  • 213 Answers
SOURCE: Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Posted on Nov 27, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Posted on Jul 04, 2009
SOURCE: 90 series Kenmore washer won't spin
You need a new timer. The clicking sound is the timer knob going and your washer not "agitating" is the result of the timer knob not sending the signal to the rest of the machine.
Posted on Jul 07, 2009
SOURCE: Kenmore Washer 80 Series - Water cut off
there is a vacuum hose hooked to your water level adjuster. If that hose falls off, which it sometimes does because there is no hose clamp, the washing machine will not know how high the water is and will continue to fill. I found this out after starting my wash before bed and waking up at 6:00 to ankle deep puddles all over my house.
the fix: open the gauge panel by taking off the plastic covers on each side and unscrewing the bolts under the covers (one per side) then the gauge panel will rotate up and allow you access to the hose and other gauges
if the hose is still clamped on check for holes in it and if no holes then you may want to replace the leveler guage
Posted on Aug 23, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
We have a Kenmore 90 Series washer and the water level function has stopped working and the water does not shut off - it just keeping running - therefore the wash cycle does not begin b/c it just keeps...
The ppart you are looking for is called the water presure switch and it is located inside the control panel.It will have a small plastic hose going to it. Hope this helped.
Jun 03, 2011 | Kenmore Washing Machines
Water-level switch shorting out
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
It has a section on testing components including the water level switch:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See the following for how to release the console and cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Apr 23, 2010 | Kenmore 24032\24036 Top Load Washer
Have a kenmore 80 series washer that does not cut off water after tub has reach it's level and overflows
It sounds like a defective Water level Switch:
See the following Whirlpool / Kenmore Service manual for top load, direct drive washers.
Also see the following for how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=400785c7cf87579d23b319fdde9a00ce
The following diagram may also help locate the components.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=138
Mar 28, 2010 | Kenmore Washing Machines
Washer wont stop filling
There is probably a plastic tube running from the tub to a pressure switch which controls the water level cutoff on control panel. One can locate this by taking the backcover off and looking at the water level switch and following the tube to the connection on the tub. Tube must fit on level switch tightly for it to work properly.
Apr 27, 2009 | Kenmore 46462 Front Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Repair manuel
If you are looking for an owner's manual for your washer, go to managemyhome.com and register. This is a FREE service. Once registered, log in and locate the "Products and manuals" link under the "Home" drop down menu. There are two manuals listed for your washer in down loadable .pdf format. I hope this helps you.
Sep 02, 2008 | Kenmore Washing Machines
Kenmore Series 80 won't stop filling.
Kenmore washers
Fill switch
pull off fill knob
remove plastic trims from front face ends of control panel exposing screws
remove phillips head screws from bottom
slide control panel forward & up ~1inch then flip over backwards on top hinges
to remove fill switch
depress lock tab right side where switch body touches back of control plate
rotate counter clockwishe 45-90 deg
withdraw fill switch
remove plastic tube from switch body
Blow any water out, should be empty when washer is empty messes up pressure sensing
refit plastic tube
adjustment screw is 1/8" hex head bolt next to knob shaft
clockwise raise water level
counter clockwise lower water level
can be operated in this open position to check operation, may have to move switch between fill positions to restart fill operation
Nov 27, 2006 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
548 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
