Question about Sony STR-GA8ES Receiver
Sony STR-GA8ES Right channel outputs distorted low volume
I was hooking my receiver up to two components (DVD player and DVD/VCR combo, and the TV out). I had it working perfectly, but the overall volume was lower on all channels except DVD player. I swapped cables and then noticed the right channel wasn't working properly. The left channel is fine, but the right is highly distorted and low in volume.
I tried swapping cables and inputs and disconnecting all but the one I wanted, but it stayed the same. When I swapped speakers, the problem stayed with the right channel. This occurs on every input that I try, and on both the A and B speaker outputs - always the right.
Just to make sure, I put my older receiver back in and the speakers work fine on both channels.
I had noticed that at one point I had shifted the cables so that instead of the output from the DVD/VCR going to left and right audio, one cable was on an audio and the other on composite video. I think this is what happened.
Is there a shop manual available to pinpoint the part that is bad so I can replace it? Are parts (circuit boards or board level components) available for repair? I can solder with the best of them, but need to pinpoint the problem area. A schematic and parts list would help.
  • ryiattq Dec 23, 2008
    I have the same problem but only on the front speakers I used the power swap option on the receiver and am now running fine just no rear speakers.
4 Suggested Answers
  • 10594 Answers
SOURCE: Sony receiver STR-GA8ES
You can download required service manual from Manual Zone for small fee.
You can buy required parts for the same unit from Part Store.
Posted on Jan 18, 2009
  • 4234 Answers
SOURCE: fuzzy sound from right front speaker output
The main issue is to determine where the distortion is coming from. Does it start in the front and and get amplified or does it appear in the output section only? This will require a fixed signal and an oscilloscope to trace. Check for leaky coupling caps or leaky transistors in at the diff-amp section.
Posted on Feb 02, 2009
  • 6771 Answers
SOURCE: str-gx800es sony receiver problem- right
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Posted on Jan 10, 2011
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
Jan 10, 2011 | Sony STR-GX800ES Receiver
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Code for sony tv are 0000, 1100, 0810
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Dec 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Sep 07, 2008 | Sony STR-D665 Receiver
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
No display
it is a bad fuse or the i.c. chip is bad
Jan 02, 2008 | Sony STR-GA8ES Receiver
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Hook-up strategy
OK I will try to explain this...You need to go from your OUT TO TV output on your cable box and split that line so you have 2 lines coming out,then you can hook one to your vcr and one directly to your tv.Then you can watch tv while you are recording something on your VCR.I hope this helps
Sep 24, 2007 | Samsung DVD-V4600 DVD Player/VCR
91 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
