Question about The Watches
How to connect the clasps on dig phogary beads
How to open clasp on hugo boss yachting timer ii watch
it has a fold out clasp , holding thumb close to the clasp pull the other side upwards this should open the clasp.
Oct 11, 2017 | Hugo Boss Watches
Clasp on ladies presidential band won't stay closed
This my be fixable, take it to a good repair shop. The clasp itself can be replaced, again a good repair shop can do this. A Rolex clasp can cost $$. A non Rolex clasp may be the way to go.
Dec 25, 2013 | Rolex Datejust SS
Clasp on ebel classic ladies watch is worn. Can it be repaired?
Yes it can be. Take it to a reputable watchmaker and they should be able to adjust your clasp. Usually what happens as a watch is worn for a few years the little brackets that lock the clasps down start to push outwards. so they are not fitting snug against the lock bar of the clasp. A watchmaker should be able to use a jeweler pliers to adjust them back to normal. costs about 15 dollars.
Jan 25, 2012 | Ebel Classic Watches
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
I bought my bulova 96R105 today, the jeweler placed it on my wrist, but now I can't undo it. Please help
It may have buttons on the sides of the clasp that you must press. If you do not see the buttons on the sides of band, it is a friction fitting, and you must pull on one or the other side of the "butterfly" clasp for it to release.
If you see a large outside clasp, there will sometimes be a fold over safety. This is called a tri-fold clasp. You must pull up the hinged clasp one direction, then the main clasp the other direction. A bi-fold clasp has no safety, and can be pulled one direction to open.
Feb 04, 2011 | Bulova Diamond Accented Calendar #96R105...
I am looking for the spring loaded pin to connect the band to the clasp for model #F98-04-KC3511.
This is usually a 14-16 mm clasp spring bar. Your local watch repair shop should be able to supply it to you without a problem.
Sep 22, 2009 | Kenneth Cole Watches
Broken clasp on watch band
The only thing you do is go to service center,maybe they have an extra clasp.Somtimes customer adjusted the size of thier bracelet and when ok they leave their udjusted clasp.That's why some service center had an extra clasp.
Jun 17, 2008 | Watches
Watches Logo
41 people viewed this question
Top The Watches Experts
vince
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
