Question about HP Photosmart 3210 Printer
How to load slides and film in hp 3210 all in one printer
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 05, 2009
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
pineworks
  • 4345 Answers
SOURCE: 0xc180001 ink system fail on HP Photosmart 3210
HI please look at link it may help
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
SOURCE: I have HP Photosmart 3210 All in one. I use nebs
Solution for 3200 series HP prints that no longer print black.
I have followed the directions on using "Non-Acetone" nail polish remover and it works.
I will add a few more details on working this solution. READ all these instructions before you attempt this.
1. The brand of nail polish remover that I used was "Cutex" but the bottle should say, right on the outside, "Non-Acetone" or "Acetone Free." This is what you need to clear the blocked ink receiving nozzle and or ink feeding tube.
2. The best syringe to use is a small "3 cc" type. I started with a "10 cc" but the diameter size of the syringe hit up against a square piece of the plastice molding on the printer. The smaller one does not.
3. Pull the ink cartridge out, locate the two ink receiving nozzles on the printer. They are small, less than 1/4 inch long. The bottom receiving nozzle on the black was plugged on my 3210 HP printer.
(The nozzle fits into the stem on the syringe.)
4. Pour some the "Non acetone" nail polish remover into the cap of the polish remover bottle. **** up 2 cc's of nail polish remover, hold up the syringe and remove any air until some nail polish remover comes out the end.
5. Get a flash light in one hand and illuminate the nozzle and the syringe in the other hand and insert the nozzle into the end of the syringe (no not try to have a needle or filler needle on the end of the syringe-it makes a mess).
a. Slowly apply pressure to the punger of the syringe. Very little will go in initially but when it does--slowly pull the plunger back. The solution will turn black.
b. Do this process 3-5 times until you can inject get about 1cc into the nozzle. Once this happens you can try to **** it back out. You will not get it all back but it helps break down the clog.
6. Once you can get 2cc's into the nozzle try the other nozzle to see if it is plugged as well. The nozzle that is plugged will offer a lot of resistance and you may have to push hard to get the initial amount in, BE CAREFUL not to push the clog way into the tube--repeat process 5b until it pushes a little easier.
a. The nozzle that is not plugged will offer very little resistance when pushing on the plunger.
7. Once you are at this point, run a "Clean print heads" and then "Align printer" from the printer menu. a. Push "set up" button on left side on menu panel. b. Push down arrow to item 2 on the display window "tools" and you will find "Clean print head" & "Align printer."
Run this a couple of times you should start to see some black ink printing on your paper (make sure there is ink in your cartridge)
8. Initially, the color will be gray. Next, go to your word processing program and make a document that has one inch wide lines on it. Run about 8-10 lines on a single piece of paper, adjust the ink flow to auto/600 dpi on the properties menu of "print" and print 10-15 pages of this to get rid of all the nail polish remover in your print tubes that lead to the print head. The color will start with grey and eventually turn black. You will know the nail polish remover is coming out because the paper will smell like finger nail polish remover.
Try this and it should work for you as well.
Posted on Feb 20, 2010
I have a hp photosmart 3210 all-in-one and i cant figure out where the paper goes
For problems like this you can always refer to the manual. If you do not have the manual it can easily be found on HP's website under their support section.
The paper loads in a small tray in the front of the machine, underneath where the printed paper exits.
Jan 15, 2010 | HP Photosmart 3210 Printer
My harddrive was completely clean. i can't find
You could download the same from :-
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?sw_lang=5&lc=en&dlc=en&cc=cz&man_lang=cs&product=439488&lang=en
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | HP Photosmart 3210 Printer
Need to scan film from hp photosmart 3210 to the computer. Tells me that to refer to device documentation to troubleshoot
For general support for your printer please go to the online HP site by clicking here.
For the instructions on Loading & Scanning Negatives & Slides please click here.
You will find they have an excellent support site online that can guide you through many troubleshooting steps for your printer. If you are not successful with the standard troubleshooter, please do a search on the error messages or results you have experienced and see if that doesn't turn up the appropriate solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 07, 2009 | HP Photosmart 3210 Printer
Paper jam in an HP Photosmart all in one 3210
look at the rear of the machine for an access door.
Feb 03, 2009 | HP Photosmart 3210 All-In-One InkJet...
Manual to copy Slides
Hi
You can download a
  • A User Guide - HERE
  • A Setup Guide - HERE
If you need anything else, let me know.
Jan 12, 2009 | HP Photosmart 3210 Printer
Can't Print
HP Paper Feed Cleaning Kit - Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00754199&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
ou may not have the paper width set snug to the paper to feed correctly.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553862&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
Consult http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601439&cc=us&lc=en&dlc=en&product=439488 regarding "out of paper" errors Paper cleaning kit is included in this article.
Apr 19, 2008 | HP Photosmart 3210 Printer
HP 3210 failure code
Hi Pddunstan,
Please click on the web link given below and perform the steps as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=us&lc=en&dlc=en&product=439488
Else please chat with HP online technical support.
The chat support is free of cost, where you can chat with HP online technician.
http://ipgweb.cce.hp.com/ipgna/caller/chat.asp?dd=aio&productName=HP+Photosmart+3210+All-in-One&productCategory=421635&SCOID=238445&PSOID=439599&aoid=null&lang=en&cc=us
Have a great day!
Mar 09, 2008 | HP Photosmart 3210 All-In-One InkJet...
It want Install...!!
Go to this website if you haven't installed the software. Download the driver and then install it, and the installation should walk you through the process. If it doesn't detect the printer, it could be a bad cable. Make sure that the cables are inserted tightly and the power is on. Hope this helps!
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-42045-1&lc=en&cc=us&dlc=en&product=439488&os=228&lang=en
Nov 07, 2007 | HP Photosmart 3210 Printer
Paper won't load up....
Disconnect the printer from power source and computer. Remove the rear access panel and very carefully use a alcohol moistened cotton swab to clean the all the black rubber pick-up rollers. Use a gentle sideways stroke while cleaning and turn rollers to clean all sides. Allow the rollers to dry and replace the rear cover and power up. Worked wonders for me. HP has certain 3210 printers that have this problem.
Oct 25, 2007 | HP Photosmart 3210 Printer
Clicking Noise
Go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00587637&lc=en&cc=us&dlc=en&product=439488&rule=44236&lang=en and I think you'll find what you need to solve the problem. often this type of error is caused by trying to clear a paper jam by pulling it out the wrong way, one or two of the gears slip and everything gets out of sync. If you can't solve your problem with the HP troubleshooter, please ask again and I can try and talk you through the resetting process. Hope this helps:)
Feb 27, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
18 people viewed this question
Clive
Clive
