Question about Asrock K7S41GX Motherboard
USB45 Socket connections
Anyone got the connector idents for the USB45 socket.
I just descovered the connections are seperate sockets - not a block.
All connectors are identified, but not the pins.
  • 113 Answers
You can download the manual here:
which lists the pinouts for the onboard USB ports. I'd post the port info itself, but it is a graphic embedded in a PDF, so can not copy and paste it here.
Posted on Jan 25, 2008
What is a step plug on a camshaft sensor synchronizer
Non-Step Style - If you look inside the connector on the Camshaft Position Sensor; you are looking at the socket (female) side of a quick connect plug. For the non-step style plug socket, the hole is the same size in the front of the plug socket as it is at the back (bottomed out in the socket hole) end of the plug socket. This means the tip of the plug (male end of the quick connect) from the vehicle will be the same size as the back end of the quick connect plug, (no step down in size.)
Step Style - If you look inside the connector on the Camshaft Position Sensor; you are looking at the socket (female) side of a quick connect plug. For the step style plug socket, the hole is large at the front of the socket, then about .25 (1/4) inches into the socket, the size of the socket steps down about .0625 (1/16) inches. This means that .25 (1/4) inches into the socket, the socket hole steps down and is smaller than the socket hole at the front of the socket. The smaller socket dimension remains this size the rest of the way back (bottomed out in the socket hole) of the plug socket. Looking at the vehicle side of the quick connect plug, the tip of the plug (steps down in size.)
Feb 17, 2013 | 2001 Ford Taurus
2004 Chevy Impala lowbeam headlamp socket/connector burns--though bulb is fine. Replaced once already and now same socket has burned again--and the bulb is still okay. What gives?
Hi Miles, Have you replaced the head lamp bulbs and maybe used a higher output? That can overheat the fuses and or the connectors. The over heating and damage will usually be caused by loose connections causing high resistance and heating. Make sure the connections are tight. Regards John
Dec 12, 2011 | 2004 Chevrolet Impala
I was taking apart my computer and can't figure
All of the cords have different ends, so that they will ONLY fit where they SHOULD fit.
If two components have identical connectors (such as printer and web-cam),
you can connect them anywhere that they fit.
#1 if your keyboard and your mouse have identical connectors,
connect the keyboard to the socket CLOSEST to the edge of the back-panel,
and then connect the mouse.
Note that the connector on the keyboard may be purple,
and the connector on the mouse may be green,
and the sockets on the motherboard may also be purple and green.
#2 your speakers need to connect to the GREEN socket,
and your microphone (if any) needs to connect to the PINK socket.
Jun 04, 2011 | Foxconn Computers & Internet
The antenna/cable connector looks broken. can this be replaced?
In most models of Sharp Telivisions,antena socket is an integrated part of the tuner itself and cannot be replaced with an other one. There is only one way and is to replace the tuner itself.
If you don't mind of style, you can solder two wires, one from the center pole of the antenna socket, and other from it outer rim, and take it out and connect to an external ariel socket [can be bought from electronic sparepart shop as a seperate socket] , to whcih you can connect your ariel pin. It will look a little dull, but you can face the probelm, without replacing the tuner. When making these connections, use sigle cored shield wire. It center wire must connect to the center pole of the broken tuner socket. OK.
Dec 09, 2010 | Sharp 27N-S300 TV
Sv400 rev 1.0 motherboard the mic sockets are not working the rear socket has been linked out (speaker socket still workin) the front socket has 5 unconnected wires (mic power, mic in, ground, r-out,...
each motherboard has different pin connection, so its best to check the booklet that came with motherboared, in the book there is color colding for mic and headphone.
Feb 10, 2010 | Computers & Internet
Just bought PB Ixtreme x5620. i am trying to connect my virgin broadband to the pc. i have netgear router which has the yellow cable in the moden and router and the blue cable in the PC and router. i can...
Can you supply more detail of your network setup? You have a broadband modem, a seperate router and the PC.
For this setup cabling should be ....
1. Phone Socket (Pref. Master socket) to ADSL socket on modem
2. Modem LAN socket to Router WAN socket
3. Router LAN socket to PC Ethernet socket
Usually in this configuration you will have to switch off DHCP on either the modem or the router as they may both be trying to supply IP addresses to your PC. I would suggest disabling DHCP on the router and leaving the ADSL modem to supply IP addresses. If you do this you will have to setup the Router with a valid fixed IP.
Have fun!
Oct 25, 2009 | Computers & Internet
Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Jun 03, 2009 | 2006 Subaru Forester
I need to know how to run my ps3 thru the optical wire to my hdtv
Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
You can connect your Playstation 3 to your TV in three different methods:
  1. Connecting with an AV cable
  2. Connecting with an HDMI cable
  3. Connecting with an Optical Cable
Connecting with an AV Cable:
  1. You are supplied with a Composite AV cable which would typically look like the below image
  2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
  3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
Connecting with an HDMI Cable:
HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
  1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
  2. Connect the other end to the socket on the back of your TV which says HDMI IN.
Connecting with an Optical cable:
You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
  1. Connect one end of the optical cable to "Audio Out" socket on the console
  2. Connect the other end to the audio receiver.
Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
Dec 11, 2008 | Computers & Internet
Emachines t2865
Most Monitors. Have A Seperate Power Cord.
They vary in shape and size. 2 pin 3pin et,c.
Have a good look at the back, and check. you should have a power connector socket inlet. And a cable out socket, to connect Monitor To Sound Card On The Back of the Desktop.
These can be located on the back underside of the monitor.
if in doubt search for your monitor make and model on the net, and try to get some instructions.
hope this helps Mike.
Feb 17, 2008 | E-Machines eMachines Desktop PC
Every phone socket must have a working microfilter pluged as shown on the image below.
I think you need to change your microfilters as they might have blown.
Hope this helps,
Abdul Qayyum
Nov 05, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Asrock K7S41GX Motherboard Logo
949 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
