Water leaking Hi, This site wouldn't let me post my problem, unless it was in a certain category, but water softeners are not there. So I am taking a chance to see if you can help me - I hope I do not waste your time! I have water leaking from my Aqua Pure Model No 268/760 water softener. the leak is near the bottom of the control valve, and I am thinking it is simply an O-ring needing replaced. Do you agree? Is this something I could replace myself? If so, how do I go about it? Thanks, Jan
Salt light means your dishwasher using water softener unit.
Salt light is on when either the salt (used for softener regeneration) is low or the water softener unit is not working correctly. First try and recharge the salt in the container usually the lid is on the base of the dishwasher. check this site for some idea. However, if there is water in the salt reservoir then you have to call the technician and get the whole softener unit regenerated.
Hope it is not all that serious. Please rate this solution if helpful otherwise post a comment.
To try and answer your question I will assume firstly that 'in service' means in normal operating mode - not in re-generation.
All water softeners have a limited throughput of water. In other words the volume of water that can pass through the system and be softened in the process is limited by the size of the vessel. If water passes through at too fast a rate then there would not be sufficient time for the water to undergo the ion exchange process that softens the water. Therefore the softener constricts the flow to a level which provides satisfactory operation.
If your plumbing system is taking water directly through the softener then the pressure will be limited by the maximum throughput of the softener. The only way to solve this is to install a higher capacity softener or, as is common in the UK, to feed a cold water storage tank from the softener so that pressure is not affected.
If you mean that 'in service' is when the device is re-generating, then the problem is a different one. When the device re-generates, it switches the water flow to bypass the softener within the unit. Therefore the pressure should not be affected unless the bypass is partially constricted. This bypass valve is an integral part of the softener valve assembly, so this would have to be checked by a competent service engineer.
If you can provide additional information by posting a comment I will do my best to help further. If you do so please identify the brand and model of your softener and try to describe how it is plumbed in to your supply.
Well Dishwasher salt is a particular grade of sodium chloride salt, and is used for recharging the built-in ion-exchange resins of the water softener in dishwashers that have a built-in water softener. The salt particles are larger than the size of table salt particles, and dissolves slowly enough that it will not clog the softener unit. This salt does not have added iodide salts, and it should have minimal amounts of iron and manganese salts. Some dishwasher detergents are marketed as not needing dishwasher salts. These detergents use higher levels of phosphate that increases the solubility of hard water ions. Never use table salt or detergent in the salt compartment of your dishwasher as this will damage your water softener unit. You can purchase the dishwasher salt from the below link -
the draw of softener need to fill with water "untill certain level" at only last rinse cycle >
so you need to check the pressur of inlet water and the inlet filter it may be clogged
thanks
Time for a new water heater, it's leaking there because that's where it can get out - tank shot - not repairable. (Unless it's actually leaking out of the drain valve(which can be threaded out and replaced) but that would only leak if someone has tried to open it.)
hiya was a bit puzzled at this one ? but will try to help not certain re your machine about bleach in dispensor but consulted the wife about bleach in our machine and no where in the manual does it mention use of bleach only softeners ? however you mention dispensor does not dispense ? try this? remove/pull out drawer and clean out the machine where drawer fits of any residue powder alsi the softener dispensor remove from drawer and ensure the cap is good fit on the dispensor tube ? if loose? then the dispensor will not work as it is emptied of softener//bleach by syphon effect ie as like toilet flush? as water enters rises to tor of tube then the fluid in compartment is syphoned along with water that is entering on rinse? cycle so if no syphon? water will o/flow/fill the drawer on l/h side and may o/flow leak from drawer ?? hope this helps? and you understand the syphon effect for using softeners ? ps i may be mistaken about use of bleach but prior apologies if iam wrong
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
