Question about HP LaserJet 3800dn Printer
Hp laserjet 3800dn service euro 49.2f81 - HP LaserJet 3800dn Printer
    Problem Solver:
  • 19 Answers
Error 49 or 79 is a conflict from your computer or print driver. Turn printer off and cancel any and all jobs in printer queue.(via your computer) Unplug the USB or the network cable and power down your computer. Power up your printer, see if it comes to a ready state. If it comes to ready go to printer menu and print a report. If this prints fine, replug cable to printer, power up computer, and send another job to printer. A corrupt job or PDF is usually the culprit in this situation. Hope this helps.
Posted on Feb 13, 2019
5 Suggested Answers
SOURCE: 49.4C02 Service Error message on
the paper will be removed later
Posted on Dec 05, 2008
  • 191 Answers
SOURCE: hp laserjet 3800dn printer is showing 50.09 error
your pc in remover the printer and un instol the printer and again instol
the printer driver cd aply and chouse your printer and restart pc.
Posted on Sep 15, 2009
SOURCE: My HP laserjet 3800dn gives
hp says a pca board has tro be replaced, cost $400
Posted on Sep 12, 2010
  • 699 Answers
SOURCE: Can I make convert my
You will need to buy a 'hp color laserjet auto duplex unit' to effectively turn your 3800n to a 3800dn and change the printer onboard controller but cost would probably more than buying a newer model with automatic double side printing support ... It is technically possible but I would not recommend it.
Posted on Sep 24, 2011
49.4C06 SERVICE ERROR For HP LaserJet 3800dn..Anyone had this code??
You need to update the firmware on the printer. This error indicates that the printer has received a print command it does not understand. Go to HP.com and search for updates for your printer.
Jun 27, 2016 | HP LaserJet 3800dn Printer
Can I make convert my HP laserjet 3800n into a 3800dn so i could print double sided automaticaly ?
Sep 24, 2011 | HP LaserJet 3800n Printer
Hp 3800dn, it says the magenta toner is missing when it is installed. have try several different magenta toners thimking bad toner cart, also have rebooted the printer, ideas? Mark
Using the control panel, run the "disable cartridge" check test. Using this test you will be able to put the magenta toner in another slot. If it works there(in another slot), put the black toner in the magenta slot. If the black doesn't work...the slot is bad. At this point you should be able to call in a printer tech to actually do hands on troubleshooting.
Sep 02, 2011 | HP LaserJet 3800dn Printer
How can I solve the proble of 59 FO error code appear in the HP laserjet 3800 printer
The error says that "The transfer rollers in the ETB are not
engaged."
If replacing the ETB(electronic transfer belt) doesn't fix the problem, your printer is going to need a technician. Problem could be poor seating of the cables on the ETB motor or the 'transfer-roller separation solenoid or the DC Controller.
It could be a bad ETB motor or solenoid or DC Controller or high voltage power supply.
This isn't something that is going to be fixed by email.
I hope you have a service contract for your printer.
Feb 18, 2011 | HP LaserJet 3800dn Printer
HP Laserjet 3800dn leaves roller imprints in Photo Paper when fed from Manual Tray only. Have identified it is a silver bar with 4 Grey cylindrical Rollers, and the 2 inner rollers are leaving the...
So far as I can tell from HP PartSurfer and the service manual, the only way to change that roller is to change the entire paper pickup assembly. The part number for the latest version is RM1-2755-080CN.
You will need sight of the service manual for the installation instructions as a fairly extensive strip down is involved (all the cartridges, the transfer belt, duplex fan, front cover, output bin, fuser, upper cover, rear lower cover, left cover, and a small bracket and an internal cover along the way). It doesn't look that difficult a job, though it is unlikely that you will chance on the correct installation method without the instructions.
I'm not feeling that happy with HP. My fuser sleeve is damaged; toner sticks to part of it, ruining the printed pages as it comes unstuck. The sleeve is very hard to obtain (I can find some mention of it on Australian eBay whilst I'm in Europe) and there's no instructions to strip down the fuser and change the sleeve in the service manual. Instead, the service manual tells you to fit a complete new fuser and that is the only part listed on PartSurfer.
This leaves me with little other option than replacing the entire fuser, which is in extremely short supply and therefore only available at an elevated price <sigh>.
Feb 22, 2010 | HP LaserJet 3800dn Printer
Hp laserjet 3800dn printer is showing 50.09 error
Sep 15, 2009 | HP Hewlett Packard LaserJet 3800dn Printer
Printer prints a colour dot at every pages edges
Hi ,
if u get red dots on print it may be problem with Red cartridge Lick age please check u r printer with Ok cartridge .if same problem with new cartridge then u need to clean Mirror built in lance assembly
Jul 11, 2008 | HP LaserJet 3800dn Printer
HP LaserJet 3800dn Printer Logo
Clive
Clive
