Canon PIXMA MG3150 Inkjet Multifunction Printer - Colour - Photo Print Logo
Beata Wilk Posted on Feb 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Canon MG3150 and after refilling cartridge have b and c ligh flashing. Printer cant print form PC but is working when hitting copy button.On the pc info coming that new ink has been installed.
Blake Whiteside
Level 2:
Habit-Forming:
  • Expert 57 Answers
  • Posted on Jun 12, 2019
Blake Whiteside
Expert
Level 2:
Habit-Forming:
Answers
57
Questions
Helped
12698
Points
151
Troubleshooting
https://ugp01.c-ij.com/ij/webmanual/Manual/W/MG3500 series/EN/CNT...
5 Related Answers
Anonymous
  • Posted on Jan 01, 2009
SOURCE: Canon Pixma MP500 error
ok I figured out what to do. Open the over take out all your ink cartriages. Then flip the print head level on the left hand side up and squeeze the top of the print head (where all your ink sits on) and lift it up. You may want to blow off any dust that may be in there and put the peint head back and replace al your ink put the level down and you should be good to go if not you may have to replace the head.
M Dodson
  • 4 Answers
  • Posted on Jan 09, 2009
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Anonymous
  • 4088 Answers
  • Posted on Jul 17, 2009
SOURCE: Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
Anonymous
  • 5 Answers
  • Posted on Nov 16, 2009
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
Anonymous
  • Posted on Jun 24, 2012
SOURCE: reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Ive just filled my ink cartridges but have the following error message when trying to print: (see add details section)
You need to reset the chip in the cartridge that tells the printer when it's low. The part can be found on sites that sell refill kits.
tip
Canon Pixma MX320 - How To Disable Ink Cartridge Error Detection..
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
I have a canon Pixma328 and have been refilling ink for black and color cartridges for quite sometime now. The cartridges are close but after I drilled a small hole on the top part of the cartridge using a small screw, there I find a way to refill the ink that I bought from an ink refill store. The procedure needs extra care, not to touch the contact point (copper) because its sensitive and not to damage the inner part of the cartridge when I insert the needles of the syringe used for transferring ink.
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
You can print as long as you want, refill the ink as long as you want and save a lot of money from buying a genuine canon cartridge by just following this simple tips for Canon Pixma MX320 and/or Canon Pixma MX328 all-in-one printer
For those who have replaced their ink cartridge before try to use that again and do follow this tip to make that work again.
tip
How To Use Refilled Cartridge When Canon Pixma328 Detected Cartridge Errors!
How to use refilled cartridge when Canon PIXMA MX320 series detected already errors in your cartridge?
Pixma mg3150 ink there but showing as empty
When using replacement or refill, Canon software will not detect them as new or filled with ink. Original cartridges have chips programmed with "counters" which determines how many times it could print. As long as it is printing, it is not really a problem just press the resume button.
Canon Pixma MG3150 not printing or lifting paper from the input tray?
Please check the cartridges.Re install the cartridges properly and try.
if ink is dried refill the ink.some times will happen to new printers also.if waranty is there cary to nearest service point.
2helpful
Disable cartridge monitor Canon MG3150
try tthis
Press and hold the Stop/Reset button until the error clears.
If your printer doesn't have a Stop/Resume button, use the Cancel button. Hold the button - until the Alarm LED stops flashing,
or until the error message disappears. This takes 6-7 seconds.
Note: You will have to repeat the whole process with every cartridge that indicates empty (in the ink monitor).
Good Luck
Thanks
2answers
Canon mp190 error e5, with refilled cartridge will not reset, even though the error only came on after the printer had already worked with the newly refilled cartridges. Ive tried the reset/power button...
Hi. Try to reset the printer using the procedure below.
Manual Reset for Canon Pixma MPC190 Printers
  1. Enter the service mode SERVICE MODE – pressing buttons Menu, Copy, Scan, Copy, Copy
  2. Choose TEST MODE.
  3. Select 8 PRINTER TEST TEST MODE.
  4. Choose 3, EEPROM CLEAR
  5. Select 0, INK COUNT
  6. Press the Set button.
  7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
3helpful
My canon printer mp190 ran out of ink while printing. The ink was a refill. I bought new refill cartridges for color and black and cannot get it to reset. It keeps flashing E at me. I have held the reset...
well, you need to get NEW cartridges because there is a NON-resetable ink level sensor, once that detect no ink is left in the cartridge, it reports a empty cartridge to the printer, no way to change that, the only fix is to replace the cartridge with a new one, on epson printers you can reset the sensor, most other brands you cant
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
shows empty cartridges but it will printing.
8helpful
6answers
Canon MP180 Ink Problem
lads ye're all I work in an 'ink place' and the u051 fault is a fault indicating that the offending cartridge is electrically dead, this is caused by the clever little program in the canon machine that writes info to the cartridge to make it'dead' so it cant be re-used ! possible solution is to get refilled before printer thinks it empty !!
old marine
old marine
ZJ Limited
ZJ Limited
