SOURCE: Storage and Media - Hard Drive External
Here is a link to Seagate's website Download area. All manuals should be available for download from there: MANUAL
SOURCE: Seagate Free Agent Drive cannot be modified? Worked before...
Ok,
Sounds like it's one of three things then
Disk trouble from unplugging the usb while the unit is still "running" and not yet finalized. Running CHKDSK /? /F in the run box where ? = extrenal drives lettrer. Then restart the computer(done from windows PC with drive attached)
Shell trouble I have already advised a dozen or so people this week that if CHKDSK doesn't work, replace the shell with a new one and see if the hard drive works in the new shell.
Failed harddrive, of course this is always an option. If neither of the above suggestions works then it's possible the hdd has failed and you may need to send it to a pro if you have any files on it that need retreiving.
Hope this helps FixYa, if you need additional help just reply to this by adding a comment.
Chris
SOURCE: Seagate external drive locked in "read only" ,was working fine...
This seems to happen when it's been connected to another computer. Are you running FreeAgent Sync? If so force a sync and the read only problem should go away.
SOURCE: seagate external hard drive green light blinking
that problem means that it is acsessing the files on it. it is not a worry for you.
Hi Stephanus , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
what is the operating system on your home computer ?
windows 8 ?
see thishttps://answers.microsoft.com/en-us/wind...
look for johnnyj2015 solution as I have had the same problem with windows 8
