Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer error code
Not sure what is E - 3
E-3 indicates a paper jam. Turn the power off. Try removing the paper and lift up the scanner top to see if there is any paper, debris, or foriegn object in there. Gently remove anything you find. Turn the power back on and press the start (black or copy button) and hopefully you will have cleared the problem. If not, you can try to reset the machine by turning it off, unplug it from the power source and remove the USB cable if it is connected to a computer. Plug it back in and turn the power back on. If this still does not clear your error, it may need to be serviced. I had this same problem last night. I did not find any paper jammed, but there was a small black twisty tie stuck in under the roller - it took me several tries and over two hours last night and another 2 hours today to discover the problem. It works fine now. However, before my second try at fixing it today, I had given up on it and purchased another printer online. Now what will I do with two? Hope this helps you. You can also try calling Canon tech support at 1-800-828-4040.
Posted on Nov 29, 2007
Error code 69.00
A printer error occurred where X is
detailed below.
0 The duplex mechanism failed
1 The duplex side-adjust failed
________________________________
1 Turn off the printer, and then
turn the printer on to
continue.
2 Reseat the duplexer (make
sure that the printer is turned
off).
3 Perform a service test. See
page 213.
4 Perform a paper-path test.
See page 213.
5 If the error persists, replace
the duplexer (make sure tha
Apr 22, 2013 | HP LaserJet 9050 Printer
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 25, 2011 | OKI C5200n Laser Printer
Fatal error 708
Dec 14, 2010 | OKI C3530N Color MFP Printer
What does error code 3820 mean for a kodak esp5 all-in-one printer
The error message "Carriage Home detection failed" (error code 3820) can be resolved by following these steps:
To resolve this error:
1.Open the printer access door.
2.Disconnect the power adapter from the printer.
3.Gently hold both sides of the carriage, located immediately behind the print-head, and make sure the carriage moves freely.
•If the carriage does not move freely, contact Kodak.
4.Remove the print-head and ink cartridges.
5.Reinstall the print-head and ink cartridges, making sure each clicks into place.
6.Connect the power adapter to the printer.
7.Turn the printer on, if necessary.
8.Close the printer access door.
If the error continues, contact Kodak.
Sep 07, 2010 | Kodak Office Equipment & Supplies
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
May 08, 2010 | OKI C9600hdn Laser Printer
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Getting error code 04C300 00310000
    Hi;
    if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
    1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
    correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer
    ON again. If this error code continues to appear then replace the EIO card.
    2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
    Replace the Hard Disk Drive.
    3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
    May 26, 2009 | HP DesignJet 1050c InkJet Printer
    Code errors on kodak easyshare esp 3
    error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
    for more hrlp visit CBR Tech Solutions
    Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    I have error code h 3
    this problem can be cause by three things abadheat lamp/thermalfuse/thirmister make sure the sensor is clean first the thermal fuse is self resetting when it cools down.
    Apr 09, 2009 | Xerox WorkCentre XD155DF Laser Printer
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    old marine
    old marine
