Question about Royal Office Equipment & Supplies
How to remove to change the ribbon on a Royal blue Apollo gt model number sp- 8500
2 Suggested Answers
SOURCE:
squipps
  • 204 Answers
SOURCE: How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
Posted on Dec 19, 2009
Im trying to replace the belt on an apollo 12-gt model sp-8500 but i cant get the cover off that exposes the belt. How do i do it?
Remove the screws from the bottom, also on the left and right side of the case, moving the carriage so you can see the screws.
On some the machines the case is snapped to gether even after you take out the screws.
Jun 23, 2016 | Office Equipment & Supplies
How to get into Royal 310PD calculator to change the ribbon
Good morning Norma.
Some searching about suggests this system has been around for a while. The Royal website has the ribbon at
royalsupplies com Looking a bit further, their collections of manuals doesn't include the 310PD, but the site says that if your product isn't listed, to call their help line at 888-261-4555. This is likely your best bet for finding some assistance from people who know the product.
Hoping that helps, and good luck!
D
Aug 20, 2015 | Royal Office Equipment & Supplies
Royal typewriter drive belt and ribbon for 44212520
Donna,
We should have a belt in stock for this model and ribbon as well. The ribbons is a standard one we refer to as a T-5 (General Ribbon product), this ribbon has an eyelet at both ends of the ribbon which is designed to activate the ribbon reverse. I you need to reach us for further assistance you can reach us at (561) 439-7766.
Jun 30, 2014 | Royal 1980s Academy Electric Portable...
How do you remove the ink cartridge from a Royal Alpha 2001.
If memory is working there is a lever with a red end just to the R. of the ribbon, pull it toward you untill it stops the ribbon cassette should lift out.
DickyO
Mar 31, 2012 | Royal Office Equipment & Supplies
Dec 15, 2009 | Royal Office Equipment & Supplies
The ribbon wont advance
The ribbon drive on this model are gear driven..a .may be off, a loose set screw on one of the gears..the ribbon may be the wrong one or it has a ribbon reverse lever on the side of the machine, this should be free of binds.
Hope this helps........
Squipps
Oct 07, 2009 | Royal Office Equipment & Supplies
Adjust spring preload
There are no preload, compression or rebound adjustments on either end of a 1996 Royal Star. The front fork characteristics can be changed by internal modifications to the front fork piston and a change in fork oil weight (stock is 5W), lengthening the spacers immediately beneath the cap bolt, or addition of progressive springs. The rear shock absorber assembly is a unit with no serviceable parts, no modifications are practical. The only aftermarket suspension parts I've found for the 1996-1998 Royal Stars are kits offered by Hyperpro (ECM), they list kits for the front forks SP-YA13-SSA05 and the rear SP-YA13-SSB05; however, since the rear kit is purported to fit all years from 1996 to the present, and the rear suspension was redesigned for the 2002 model year, I suspect that you may find that the rear kit doesn't work at all.
May 31, 2009 | 1996 Yamaha Royal Star XVZ 1300 A
SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
www.TulsaBiz.net
Apr 07, 2009 | Datacard SP55 Plus Printer
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
51 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
