Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Wont power down after shutdown
When shutting down system everything works fine but after windows shuts down the computer wont power off ,i have to cut power to the comp to be able to restart it the little yellow light stays on on the front of the comp
  • 4 Answers
Your operating system is screwed up,backup your files and reinstall with the restore disk/repair ,good luck
Posted on Nov 28, 2007
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/ for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Why does desktop pc running win xp pro, when choosing "start/shutdown/restart", fail to restart, but if choosing "start/shut down/shut down" it works fine?
May 23, 2014 | Computers & Internet
My dad's Dell Dimension 2350 windows XP home edition won't power off when you try to shut it down .
There is one solution that you can do, you can hold the power button for about 10 seconds and this will shut your computer down, this is known as a hard shut down. My question would be how often does this happen? If it happens at every shutdown I would recommend scanning your computer for viruses and malware. If that doesn't fix the problem I would recommend backing up your data and restore your operating system.
Nov 02, 2013 | Computers & Internet
When logging off my laptop, and before going into shutdown, I closed the lid on my laptop. The window is now stuck showing the prepare to shutdown screen. The mouse pad still works but nothing I push will...
Try holding down the power button until the computer force shuts down. If that doesn't work, you may need to pull the battery. Don't worry about damaging files, everything should be fine. When Windows boots up again, you just need to select "Start Windows normally".
Aug 14, 2011 | IBM ThinkPad T60 Notebook
I have an Insignia desktop computer with windows xp. Everything will be working perfectly fine and the computer will shut off without a warning or actually going through the shutting down process it's as...
The shut down might be caused by overheating - clean it thoroughly on the inside and raise the shutdown temperature setting from the BIOS.
Yes, the internet is not related and it has to do with how you connect - most likely you have a very bad line. The only ones that can fix that are the guys from your ISP - they must check your cable and the modem itself.
Nov 18, 2010 | Insignia D400a PC Desktop
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
Windows xp is not starting
Dear Customer
please undergo the following
when the power cut off windows shut down immedeiatly and when u start your system wont boot this mainly because corruption windows files if its abruptly shuts down the current windows will get corrupted so better use an UPS for a standby atleast for few minutes so that u can properly shut down your system so that to prevent your corruption or your system files.This may help u.
Please rate this,Thank u
Dec 15, 2008 | Umax Tech Refurbished W/AMD K6-2 300MHZ...
Windows xp on acer aspire 4315 cannot shutdown normally
Dec 05, 2008 | Acer Aspire 4315 Notebook
try to add-on memory that compatible to your computer so that your computer become faster.....
Dec 17, 2007 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
123 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
