Question about IBM ThinkPad A31 Notebook
Works only with AC power plugged in; battery is recently replaced
Hi all, my A31's battery was replaced about a year ago. It's used mostly
while plugged in, but the battery was working fine. It shows a 93% charge.
The problem is that the laptop turns off the instant the power plug is pulled.
Anyone know how to fix that? Is there a certain power board that can be replaced? I replaced a power inverter for the LCD screen about 6 months ago.
It's very nice machine with a beautiful display. I'd like to keep it going.
It is a loose or broken battery.
93% ? i think it's shorted out.
Posted on Dec 28, 2007
Laptop not charging battery plugged in but
You can try taking out your battery and use only the charger (AC adapter only ) to see if the computer works. If your battery less laptop works fine that way, it is most likely that there is a problem with your battery.
You can also try testing your battery by substituting a battery that's functional from another laptop of the same model. If the substituting battery works fine then you may need to replace your battery :(
I recently used this company to purchase a new battery fro my laptop. I have HP laptop and my replacement battery only cost about $40. If you are looking for a low cost replacement, this might be helpful. Here is the link for the company I used.
Hope everything works out well for you!
Oct 26, 2012 | Dell Inspiron 1525 Laptop
I have an a31 i recently replaced the battery it works fine but when ever i put it for charging and disconnect it when it is done the battery meter says it is still connected so i cant get my real power...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 29, 2011 | IBM ThinkPad A31 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
My IBM thinkpad a31 on works when i plug it in but i just bought a battery and it charges all the way but when it is unpluged and is on battery power it just turns off
How fast does it turn off? If it is within minutes, then the problem is the battery or the actual charging mechanism that switches from adapter to battery.
If the battery is fully charged and turns off immediately, get that particular part of the laptop checked out. It probably will need replacing.
Aug 10, 2009 | IBM ThinkPad A31 Notebook
IBM thinkpad A21 won't start up
1# remove the battery from the thinkpad and ac adapter.
2# hold the power button for 40 seconds.
3# plug in the ac adapter and turn on the botton.
4# see it for works what trying to do to thinkpad is recyle the power .
give it a try and see if it work if it doesnt let me know
Apr 14, 2009 | IBM ThinkPad T21 Notebook
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
I hope this helps.
Nov 05, 2008 | IBM ThinkPad T20 2647 Notebook
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
Digital video camcorder
Try the most obvious solutions first; making sure the AC adapter for the camera is plugged into the camcorder-- and the plug orientation is correct if applicable, and it is in turn plugged into the wall.
Is the wall outlet working? Try another location in your home to be sure. Is the AC adapter working? If you have a battery, attach it to the camera and see if it charges. Next, look for obvious outward physical damage to the camcorder that could cause it to stop working.
The thin battery you speak of if generally just for backing up the time and date, and is not needed for operation.
The power switch on Canon models is usually a slider that goes from Manual to Auto to VCR mode. If it is dirty or wearing out, move it a small amount to one side or the other, while watching the LED power indicator. If you see it flash, or light dimly, the switch is bad.
Read the manual-- the unit may have a reset function you can access, or require a tape in it to power up. Hope these help.
Nov 18, 2007 | Canon ZR70MC Mini DV Digital Camcorder
IBM ThinkPad A31 Notebook Logo
123 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
