Washing machine keeps giving holes in my clothing
    Sergeant:
  • 274 Answers
Hello what you will need to do is switch the machine off and open the door make sure it’s empty very carefully with your hand very slowly you don’t want to cut your self very slowly in till you feel something sharp or it could be a bra Bone do it make any nosies when it’s washing or spinning if you get a old cloth and like your going to wipe the drum in side if the cloth get court any where that’s why your clothes are getting holes if when you have gone round the in tire drum and you can’t find any thing it could be your putting too many clothes in the drum but most times it could be a bra bone stuck between the Elerment and sticking out of the drum get a torch Most times you can see if any thing is between the drum and outer drum any problems message me back ok
Posted on Feb 03, 2019
SOURCE:
Lumpy816
  • 246 Answers
SOURCE: neptune top load holes in clothes
You may have something between your basket (the area where you put your clothes) and your tub (the part that holds all the water in. Check all of the holes in your basket to see if you have something sticking/ protruding out of one of them. You might also have a hole that has been bent casuing a rough edge. Next pull back the edge of your boot (the gray ,rubber part in the front) Do you have any forighn objects in there? Finnaly for the washer, check the bottom of the door. A rough area on the bottom can cause the same problem. You might also want to check your dryer. Over time the seals (the gray rings in the front and back when you look in your dryer can be worn or have a forign object caught in them. Both will cause clothes to snag and tear.
Posted on Jun 15, 2008
  • 51 Answers
SOURCE: holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Posted on Mar 13, 2009
honeymokey
  • 3113 Answers
SOURCE: making tiny holes in clothes
Check drum and agitator for cracks or something that may be hooking the clothes.
Posted on May 09, 2009
  • 90 Answers
SOURCE: We are getting small holes in our clothes? Is
check to see if theres anything in the tub that feels sharp. Make sure theres nothing stuck in the small holes. Also, check out the rubber boot. DOes it look worn? what clothes are getting holes? is it all of them? Colors only? Whites only? Do a maual check on the inside of it with a flashlight to make sure no sharp objest are stuck aor what not?
Posted on Aug 01, 2009
SOURCE: My Washing machine stains clothes;
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Posted on Apr 12, 2010
Whirlpool front load dryer - gives little holes in the tee shirts and other clothing's. Sometimes it feels like its burnt and sometimes its just holes and ripped
Check for sharp edges and pinch points on the ribs in the drum that tumble the clothes. I had my drum replaced under warranty.
Dec 14, 2016 | Whirlpool Washing Machines
Washer or dryer is putting holes in my clothes
Try putting less clothes in on a wash. The main problem is caused due to draining. My brother had this problem. Try stop your washing machine before draining and hand drain them over the sink. Best advice I can give on that one sorry
Jun 01, 2013 | Washing Machines
Keeps making holes in clothes
Carefully run your hand around the inside of the washing drum to check for catches or damage, perhaps a screw or similar that has lodged in the drain holes of the drum. Remove the agitator, if applicable, and check for foreign object(s) lodged underneath.
Mar 19, 2010 | Washing Machines
Aug 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
GE Profile Top Loading Washing Machine Makes Holes in My Clothes
i know this may sound crazy but are you sure there is nothing lodged in the drum like a bra bone as this does happen,just a thoght give it a try,rgds,paul.
Jul 07, 2009 | GE Profile WPRE6100G Top Load Washer
Making tiny holes in clothes
May 09, 2009 | Washing Machines
Can i take apart the drum somthing keeps tearing my clothes
The best access to inside the tub is through the lid/door. Going in through the back will not give you any better access.
If the wire is tearing yur clothes, maybe you can see the end of it poking through a hole. If you can, put a pair of vise grips on the end of the wire and try pulling it back through the hole.
Apr 29, 2009 | Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Holes in clothes
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Clothes stink after being washed
run a empty load of just bleach and keep the door seal wiped down plus when your not using it leave the door open
Jan 11, 2008 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
