Question about Miele Novotronic Premier 500 Front Load Washer
Miele washing machine
my miele w989i wps washing machines water inlet check light flashes during the programme and towards the end of the cycle 3 horizontal - - - dashes appear in the display and the buzzer sounds continuously. i have cleaned the fluff (drain) filter and pump, removing a lot of limescale but still no joy. Any ideas please?
SOURCE: Miele w1203 fault
use the small orange tab to tighten down on the light just inside on the top of the door. i had the same symptoms and it fixed them right away.
Posted on Feb 22, 2008
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
  • 177 Answers
SOURCE: tripps electric when heating miele w989i
you may have a faulty heating element or the wire going to the element has broken off and is touching the casing of the unit. if you are confident and able to remove the front panel you will see the heating element under the drum.
Posted on Aug 19, 2010
SOURCE: Hi I have a miele W460 WPS Washing machine which
my advice open the pump filter at the bottom of the machine (on left side) ensure all is empy.
the other option is turn off the machine at the maions using a vax water hoover (or any wet and dry vacume cleaner) remove the wast pipe from sink put the hover pipe to the washing machine and **** out all the water.
sould this also fail you would need to open the machine and check the bottom on the floor (inside the machine where all the workings are) there is a cut off trigger make sure this is completely clear of any thing there would be a polystireene base with a button trigger if this is activeted it will stop the machine and cause it to continuesly run the pump this should resolve the issue please let me know how you get on i can come out into certain areas to see to this machine but i charge £50 labour charge 9 out of every 10 of theese i manage to get going again let me know my email is
Posted on Oct 06, 2010
Daniel S
  • 4323 Answers
SOURCE: My Miele W360 WPS Washing
The issue seems to be with the drain pump motor that is bad and should be replaced. However, before replacing remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor; it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Posted on Jun 27, 2011
0 characters
1 Points
I have a Miele w828. The wash programme stops and the check inlet indicator light is flashing but the stopcock is on ,the hose is not blocked and the filters are clean. What do I do?
If you have water going in to the machine then it is probably a blocked pressure bag.
If no water is going in to the machine then its probably a faulty inlet valve or blocked inlet filter.
Sep 21, 2014 | Washing Machines
Will not rince at end of wash cycle
If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
Nov 19, 2012 | Bosch Washing Machines
Washer stopping after filling,wont complete any of the programmes, emptying and filling ok,recently replaced pump and programme selector.stain vanish light flashes and top of panel for time to end light...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Jul 23, 2011 | Washing Machines
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Jul 25, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
509 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
